Api session event editor cinematic move keypoint
API Endpoint: api/session/event/editorcinematic/move_keypoint/
Description: Move a Key Point to an index of the array of Key Points of a Cinematic
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic Data
1 REQUIRED (Integer number) Key Point ID
2 REQUIRED (Integer number) Index
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorcinematic/move_keypoint/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/move_keypoint/", options)
