Api session event editor cinematic add keypoint with parameters
API Endpoint: api/session/event/editorcinematic/add_keypoint_with_parameters/
Description: Add a Key Point with the provided camera location, orientation and lookat in 3D Visualization coordinates (X is east, Y is up, Z is south)
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic Data
1 REQUIRED (Integer number) Key Point ID
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Camera Location
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Up Vector
4 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Lookat location
200 Integer (Key Point ID)
curl 'https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_with_parameters/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1.0, 1.0, 1.0 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_with_parameters/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST
 body: '[ 1, 1, 1.0, 1.0, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_with_parameters/", options)
