Api session event editor cinematic add keypoint
API Endpoint: api/session/event/editorcinematic/add_keypoint/
Description: Add a Key Point to a Cinematic
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic Data
200 Integer (Key Point ID)
curl 'https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint/", options)
