Api session event editor stakeholder
Revision as of 10:19, 13 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorstakeholder/
API Endpoints for Stakeholder editing.
Name Description
add Add a new Stakeholder
duplicate Duplicate existing Stakeholder
remove Remove existing Stakeholder
set_active Set whether a Stakeholder is an active participant of a Session
set_color Set the Color of a Stakeholder
set_name Set the name of a Stakeholder
Additional API Endpoints:
Name Description
add_land_ownership Assign land to a particular Stakeholder
add_with_type_and_active Add a new (active) Stakeholder
select_stakeholder Select Stakeholder using the preferred ID; if unavailable, fall back to the next best option
set_image Set the image of a Stakeholder
set_short_name Set the short name of a Stakeholder
set_start_budget Set the start budget of a Stakeholder
set_type Set the type of a Stakeholder
transfer_ownership Transfer the ownership of Buildings and Plots from one Stakeholder to an other Stakeholder. Optionally include Zones
reset_web_token Reset the Web Token of a Stakeholder and generate a new one with a default length
reset_web_token_with_length Reset the Web Token of a Stakeholder and generate new one with a particular length
