Web token
API Endpoint: api/session/event/editorstakeholder/reset_web_token/
Description: Reset the Web Token of a Stakeholder and generate a new one with a default length
0 REQUIRED (STAKEHOLDER Integer ID or multiple integer values in array [1, 2, 3]) Stakeholders
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/reset_web_token/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/reset_web_token/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/reset_web_token/", options)
