Web token with length
API Endpoint: api/session/event/editorstakeholder/reset_web_token_with_length/
Description: Reset the Web Token of a Stakeholder and generate new one with a particular length
0 REQUIRED (STAKEHOLDER Integer ID or multiple integer values in array [1, 2, 3]) Stakeholders
1 REQUIRED (Integer number) Web Token Length
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/reset_web_token_with_length/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/reset_web_token_with_length/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/reset_web_token_with_length/", options)
