Api session event editor stakeholder set short name
API Endpoint: api/session/event/editorstakeholder/set_short_name/
Description: Set the short name of a Stakeholder
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (String) Short Name
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/set_short_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Short Name" ]'
JavaScript example POST
 body: '[ 1, "Short Name" ]'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/set_short_name/", options)
