Api session event editor stakeholder set start budget
API Endpoint: api/session/event/editorstakeholder/set_start_budget/
Description: Set the start budget of a Stakeholder
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (Floating point number) Budget
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/set_start_budget/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 61 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/set_start_budget/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 45 ]'
JavaScript example POST
 body: '[ 1, 61 ]'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/set_start_budget/", options)
