Iteration (TQL Param)
| Param | Value | Description | Limits search polygon |
| ITERATION | positive integer | Query only executes when the current Iteration matches this value. | false |
Available for
- Select attribute (TQL)
- Select floorsize (TQL)
- Select global (TQL)
- Select height (TQL)
- Select id (TQL)
- Select gridavg (TQL)
- Select gridmin (TQL)
- Select gridmax (TQL)
- Select gridarea (TQL)
- Select gridvolume (TQL)
- Select gridstdev (TQL)
- Select landsize (TQL)
- Select landpolygons (TQL)
- Select lotsize (TQL)
- Select lotpolygons (TQL)
- Select name (TQL)
- Select units (TQL)
- Update address attribute (TQL)
- Update area attribute (TQL)
- Update building attribute (TQL)
- Update global value (TQL)
- Update grid attribute (TQL)
- Update indicator attribute (TQL)
- Update neighborhood attribute (TQL)
- Update net function attribute (TQL)
- Update net line attribute (TQL)
- Update net load attribute (TQL)
- Update overlay attribute (TQL)
- Update panel attribute (TQL)
- Update scenario attribute (TQL)
- Update zone attribute (TQL)
- Queries with these clauses are only executed when the current Iteration matches the value of this clause.
- Unlike most queries that return a default value of 0, this query does not write to the Excel cell if the iteration doesn't match.
- Update queries follow the same logic and are only executed when the iteration matches.
API Endpoints
