Api session event editor indicator
API Endpoint: api/session/event/editorindicator/
API Endpoints for Indicator editing.
| Name | Description |
| add | Add a new Indicator with a default Excel Sheet |
| append_attribute | Appended to existing Indicator numeric Attribute value |
| duplicate | Duplicate existing Indicator |
| remove | Remove existing Indicator |
| remove_attribute | Remove numeric Attribute from Indicator |
| set_active | Set whether an Indicator is active (recalculated and visible to Stakeholders). |
| set_attribute | Set Indicator numeric Attribute value |
| set_attributes | Set multiple Indicator numeric Attribute values |
| set_color | Set the color of an Indicator. |
| set_name | Set the name of an Indicator. |
Additional API Endpoints:
| excel_min_log_time | Set the minimum Time for a performance entry to be recorded in an Excel Sheet Call Tree. |
| export_debug_excel | Export an Excel Sheet, populated with data related to the Indicator, to Byte array content |
| export_excel_call_tree | Export a performance report of an Excel Sheet, populated with data related to the Indicator, to text as Byte array content |
| remove_stakeholder | Remove the association to a particular Stakeholder from an Indicator. |
| set_absolute | Make the score of an Indicator absolute, extending the allowed range. (Relative score must be between 0 and 1) |
| set_description | Set the description of an Indicator. |
| set_excel | Set the Excel Sheet used by an Indicator. |
| set_image | Set the image of an Indicator. |
| set_parent | Set a parent Indicator for a specified Indicator, making it a subselectable Indicator. An Indicator that already has a parent cannot be assigned as a parent to another Indicator. |
| set_short_name | Set the short name of an Indicator. |
| set_stakeholder | Assign an Indicator to a particular Stakeholder. |
| set_target | Set a target value of an Indicator for a Scenario. A target index value is required. |
| set_update_timing | Set the calculation Timing of an Indicator |
| swap_order | Swap the order of paired Indicators |
