YA (TQL)
The 'YA' clause value is a variation on the 'Y' clause value. The characters 'YA' should be followed by an underscore and the name of an Attribute; for example YA_MONUMENTAL.
The result of using 'YA' for the clause value is the automatic creation of multiple TQL statements, one with each Item ID for that Clause Parameter that can be found in the project data. Items are only taken into account if they have a non-zero value for the specified attribute.
Internally, both the resulting TQL statements and their results are stored as arrays of arrays.
Clause Parameters
The YA value can be used in the following TQL Clause parameters:
Example
Consider the following (simplified) Building data of a project:
{ "id" : 0, "name" : "Lindelaan 3", "attributes": { "MONUMENTAL" : [0.0], "MEASURED_M2" : [200.0] } },
{ "id" : 1, "name" : "Kerklaan 40", "attributes": { "MONUMENTAL" : [1.0] } },
{ "id" : 2, "name" : "Achterweg 7", "attributes": { "MONUMENTAL" : [-3.5] } },
{ "id" : 3, "name" : "Achterweg 9", "attributes": { } },
{ "id" : 4, "name" : "Kerklaan 61", "attributes": { "MONUMENTAL" : [2.0]} },
{ "id" : 5, "name" : "Duiker 1235", "attributes": { "CULVERT_DIAMETER" : [1.0]} }
The TQL statement to obtain the names of the monumental Buildings is:
SELECT_NAME_WHERE_BUILDING_IS_YA_MONUMENTAL
which internally is replaced with a list of TQL statement arrays, separated by a comma:
[ [SELECT_NAME_WHERE_BUILDING_IS_1], [SELECT_NAME_WHERE_BUILDING_IS_2], [SELECT_NAME_WHERE_BUILDING_IS_4] ]
Its result will be a list of arrays with names, separated by a comma:
[ ["Kerklaan 40"], ["Achterweg 7"], ["Kerklaan 61"] ]
Similarly, the TQL statement to obtain the MONUMENTAL attribute values of monumental Buildings is:
SELECT_ATTRIBUTE_WHERE_BUILDING_IS_YA_MONUMENTAL_AND_NAME_IS_MONUMENTAL
Its result will be a list of arrays of values, separated by a comma:
[ [1.0], [-3.5], [2.0] ]
- The following variants on YA exist:
- The result of an YA-queries are array of value-arrays without the outer brackets when the Setting TQL_PANEL_BRACKETED is set to 'false'.
API Endpoints
