Y (TQL)
Revision as of 12:43, 3 November 2026 by Frank@tygron.nl (talk | contribs)
Instead of specifying a clause parameter with a particular Item ID, it is possible to use the 'Y' character for its value. Using 'Y' as a clause value automatically creates multiple TQL statements—one for each Item ID associated with that parameter in the project data. Internally, the resulting TQL statements and their results are stored as arrays of arrays.
Example
Consider the following (simplified) Neighborhood data of a project:
 { "id" : 0, "name" : "De Manege" },
 { "id" : 1, "name" : "De Lancaster" },
 { "id" : 2, "name" : "De Landstreken" },
 { "id" : 3, "name" : "De Kruidentuin" },
 { "id" : 4, "name" : "Golfresidentie" }
The TQL statement
SELECT_NAME_WHERE_NEIGHBORHOOD_IS_Y
is internally replaced with a list of TQL statement arrays, separated by commas,
[ [ SELECT_NAME_WHERE_NEIGHBORHOOD_IS_0 ], [ SELECT_NAME_WHERE_NEIGHBORHOOD_IS_1 ], [ SELECT_NAME_WHERE_NEIGHBORHOOD_IS_2 ], [ SELECT_NAME_WHERE_NEIGHBORHOOD_IS_3 ] , [ SELECT_NAME_WHERE_NEIGHBORHOOD_IS_4 ] ]
Its result will be an array of name arrays, separated by commas, for example:
[ ["De Manege"], ["De Lancaster"], ["De Landstreken"], ["De Kruidentuin"], ["Golfresidentie"] ]
Clause Parameters
The Y value can be used in the following TQL Clause parameters:
  • The result of an Y-queries are array of value-arrays without the outer brackets when the Setting TQL_PANEL_BRACKETED is set to 'false'.
API Endpoints
