Timeframe
Revision as of 13:03, 13 October 2026 by Frank@tygron.nl (talk | contribs)
A timeframe is a snapshot of a specific moment in a Grid Overlay's calculation.
The following Overlays support timeframes for their results:
The following Grid Overlays can have multiple timeframes when configured with a Prequel:
Progression over time
In most cases, the Grid Overlay performs a simulation of a certain phenomenon from an initial moment in time up to a certain final moment. The timeframes show intermediate results partway through the progression of the simulation, with the last timeframe showing the final result at the end of the simulation. In these cases, each simulation step depends on the preceding one.
For example: If a Water Overlay is configured to simulate 24 hours, and output 4 timeframes with default intervals, the results will show the amount of water at 6, 12, 18, and 24 hours since the start of the simulation respectively.
Separate results
Some Grid Overlays perform multiple calculations in parallel which are then all considered parts of the final dataset. Here, each timeframe uses a nearly independent set of parameters to determine its output.
For example: The Heat Stress Overlay can be configured to calculate the heat situations for 3 separate dates or times, each with their own temperature, wind, etc.
