Region-based Convolutional Neural Network (Inference Overlay)
Revision as of 14:39, 15 July 2026 by Frank@tygron.nl (talk | contribs) (→Supported Convolution Types)
Selecting a Neural Network in the Inference Overlay Wizard
A Neural Network in the AI Inference Overlay is a pre-trained Region-based Convolutional Neural Network (RCNN) [1] that can be used to classify or detect features given one or more input Overlays. Neural Networks are stored in the Tygron Platform as data items with a reference to an ONNX-file (Open Neural Network Exchange format[2]) visible via Netron[3].
Input and output for neural networks are handled using data tensors. These tensors are multi-dimensional data arrays. They are automatically identified when selecting or adding a new Neural Network.
Whether a Neural Network classifies or detects objects given an input depends on its inference model. Such a model is created using AI software, such as PyTorch. Neural Networks can indicate what type of network they are by defining the INFERENCE_MODE attribute in their metadata.
Supported Inference Types
  1. Image Classification
    • Classifies a picture using labels, in combination with a predicted probability per label
  2. Detection (with masks and bounding boxes)
    • Detects up to several features in a picture
    • Predicts probabilities of features and where they are located
Parameters in Metadata
Neural Networks can store default parameters to ensure the Inference Overlay is configured correctly upon setup. The following parameters are used:
  • Neural networks that are not referenced by an AI Inference Overlay may be removed from your project when a project is saved.
API Endpoints
  1. ↑ Cheatsheet ∙ Found at: https://stanford.edu/~shervine/teaching/cs-230/cheatsheet-convolutional-neural-networks ∙ (last visited: 2024-09-21)
  2. ↑ ONNX ∙ Found at: https://onnx.ai/ ∙ (last visited: 2024-09-21)
  3. ↑ Netron ∙ Found at: https://netron.app/ ∙ (last visited: 2024-10-14)
