Vans per hour (Function Value)
| Function value | Attribute | Unit | Range | Description |
| Vans per hour | NUM_VANS | vehicles/h | 0 to 1.7976931348623157E308 | How many vans move over any given cross-section of the road per hour, spread across all lanes. |
This is only relevant for roads, intersections, and bridges. This affects the visualization, and is part of the traffic model, in turn affecting the calculations for the Traffic Overlays.
The value can either by a single value, or an Attribute array of values. As a single value, this reflects the amount of vehicles per hour at any point of the day. As an Attribute array, it's assumed to be an array of 24 values, each value corresponding to each hour of the day.
Values
- The default values for this Function Value are based on values selected for an acceptable visualization.
- Buildings generated during project creation can have their values overwritten based on data from INWEVA, NSL or Infomil[1][2], in that order of occurrence.
Used for
- Traffic Model
- Traffic visualization
- Traffic Overlay
- Traffic Density Overlay
- Traffic Noise Overlay
- Traffic NO2 Overlay
Model-specific articles
- Num vans (Traffic Overlay)
- Num vans (Traffic Density Overlay)
- Num vans (Traffic Noise Overlay)
- Num vans (Traffic NO2 Overlay)
- When considering doing traffic calculations outside The Netherlands, always provide roads with intensity values before inspecting the calculation results. Do not rely on the defaults.
- Buses per hour (Function Value)
- Cars per hour (Function Value)
- Trucks per hour (Function Value)
- Function Values (Traffic visualization)
API Endpoints
- Api session event editor building set function value
- Api session event editor functionoverride set function value
- Api session event editor building reset function values
- ↑ Infomil estimates information ∙ Infomil ∙ Found at: https://www.infomil.nl/onderwerpen/lucht-water/luchtkwaliteit/slag/hulpmiddelen/inschatten/ ∙ (last visited: 26-9-2022)
- ↑ Infomil VI Lucht en Geluid v4 ∙ Infomil ∙ Found at: https://iplo.nl/publish/pages/187232/vi-lucht_geluid_v4.xls ∙ (last visited: 26-9-2022)
