Green (Indicator)
Revision as of 11:46, 14 July 2026 by Frank@tygron.nl (talk | contribs)
The green indicator calculates the amount of nature and green constructions in a neighborhood. The indicator then relates this to the amount of houses in the area. A target can be set for the amount of green per house. This indicator is useful for projects where for example:
  • livability is an important aspect in the project
  • the project area should become climate adaptive
  • compensation in the form of green is required for new housing projects
Note: this indicator is the same as the default Green indicator from the Indicator menu in the Tygron Platform.
Indicator panel
The indicator panel shows per neighborhood:
  • the neighborhood name
  • the current amount of green (m2) in the neighborhood
  • the target amount of green (m2) for the neighborhood
  • how much green (m2) per neighborhood should be built
Calculation
The green indicator calculates the amount of houses and the amount of open green space and green functions. Open green space means:
Green functions include houses with a green roof or city parks. These functions all have a value for the vegetation fraction. The amount of open green space and green functions added together is the amount of green.
The indicator scores based on how much green in m² exists per house and relates this to the set target. According to literature[1], there is no norm for the amount of green per house, but 75 m2 can be used as a guideline.
The more green in the project, the better the indicator scores. A project with fewer houses will require less green than a project with many houses.
Score
The score is represented in a progress bar, with a scale from 0 to 100%. Determine if you want to calculate the absolute or relative score.
Additional configurations
For this indicator to function, a Global to set the target has to be defined. Read below for the steps.
Configuration by adding the Global (Index)
The target for the amount of green in m2 per house is set in a Global.
Green (Indicator):
  1. Select Current Situation and then hover over TQL Queries in the ribbon header.
  2. Click on Add Global in the hover panel. A new global named VARIABLE will be added to the left panel.
  3. Select the global VARIABLE.
  4. In the right panel, change the name to GREEN_PER_HOUSE.
  5. Change the start value to a number representing the amount of green in m2 per house
  6. Hover over the Auto update icon and choose Reset to Start values (faster) to update your project.
Configuration by using the Platform Indicator
You can also use the platform's Green Indicator, which is adjustable via the interface's bottom panel. Adjusting this value automatically updates the indicator target.
Editor → Current Situation (Ribbon tab) → Indicators (Ribbon bar)
API Endpoints
  1. Beschikbaarheid groen in de stad, 2000 - 2006 ∙ Clo (2010) ∙ Found at: https://www.clo.nl/indicatoren/nl029906-beschikbaarheid-van-groen-in-de-stad
