How to add a spatial Panel
Panels form a (custom) interface element for the end-user. To use a Panel, it must first be added to the Project.
How to add a Panel:
- Open the list of Panels.
- At the bottom of the left panel, select the desired type of Panel.
- Click on "Add Panel".
- The Panel is now added. Make sure it is selected
- At the bottom of the right panel, select "Add point".
- Use the brush to place a point in the 3D Visualization.
- The Panel now has a location in the project map.
- If the Panel is visible to the user's Stakeholder, a Popup will be visible in the 3D Visualization.
- If a Panel is not visible for the current state or Stakeholder, verify its location by selecting it in the left panel. If the camera automatically moves to the intended location in the 3D Visualization, the location of the Panel has been set successfully.
