Popup
Popups are used to communicate to a stakeholder when its attention is required in the 3D Visualization. Popups are rendered as 3-dimensional models hovering above the rendered height map and buildings. They are only visible to the stakeholder for whom they are relevant. When zoomed out, the visualization of a popup can change, and they can also be grouped together with other popups. Popups are considered a part of the Viewer interface.
Popups can either be related to:
- an Action, for which the types of popups are described below.
- a Panel, which when clicked on, opens a Web panel displaying the content of the Panel item in the Viewer.
Types of Action popups
Depending on the content of the popup, a popup will appear differently. Clicking on popups related to an action opens the Popup info panel.
Standard
A popup which appears when your interaction is required. This is the most common type of popup.
Land transaction
A popup which appears when your interaction is required in a land transaction, either because someone wants to buy your land or sell you land.
Pending
A popup which is currently awaiting interaction from another stakeholder. It appears when a spatial action requires interaction or approval from another stakeholder.
Approved
A popup which informs you that an action you wanted to take has received the requested approval. This notifies the user that their action was successful; only confirmation is required.
Denied
A popup which informs you that an action you wanted to take has not received the requested approval. This notifies the user that their action was denied; only confirmation is required.
