Select gridmin (TQL)
| Select | Unit | Description | Fixed clause amount | Polygon based |
| GRIDMIN | decimal | Returns the minimum grid value for the query polygons an a specified Grid | No | true |
Allowed clause parameters
| Param | Value | Description | Limits search polygon |
| AREA |
Integer (Item ID), ID, X, Y, XC, YC, XA, YA, XK or YK |
Area with ID. | true |
| AREA_WITH_ATTRIBUTE | Attribute | Area with non zero Attribute value. | true |
| GRID |
Integer (Item ID), ID, X, Y, XA, YA, XK or YK |
Grid of Grid Overlay with ID. | false |
| GRID_WITH_ATTRIBUTE | Attribute | Grid of Grid Overlay with non zero Attribute value. | false |
| GRIDTYPE |
Grid Type, X, Y, XA, YA |
Grid of Grid Overlay with specified type. | true |
| GRIDVALUE | decimal | Only include Grid Overlay cells that have a value equal to the one specified. | true |
| ITERATION | positive integer | Query only executes when the current Iteration matches this value. | false |
| MAP |
Map Type, X, Y, XA, YA |
Only Items present in this Map Type. | true |
| MAXGRIDVALUE | decimal | Only include Grid Overlay cells that have a value smaller than the one specified. | true |
| MINGRIDVALUE | decimal | Only include Grid Overlay cells that have a value larger than or equal to the one specified. | true |
| NEIGHBORHOOD |
Neighborhood with ID. | true |
| NEIGHBORHOOD_WITH_ATTRIBUTE | Attribute | Neighborhood with non zero Attribute value. | true |
| RESULTTYPE |
Result type, X, Y, XA, YA |
Grid of Grid Overlay with specified Result type. | true |
| TERRAIN |
Terrain of Terrain Type with ID. | true |
| TERRAIN_WITH_ATTRIBUTE | Attribute | Terrain is of Terrain Type with non zero Attribute value. | true |
| TIMEFRAME |
timeframe, X, Y, XA, YA |
Specifies which Timeframe to select when processing a particular Grid. | false |
| ZONE |
Zone with ID. | true |
| ZONE_WITH_ATTRIBUTE | Attribute | Zone with non zero Attribute value. | true |
- The Grid should be specified with the Grid (TQL Param) or Grid with attribute (TQL Param)
