Api session event editor levee
Revision as of 11:39, 8 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorlevee/
API endpoints for Levee editing.
Name Description
add Add new Levee
duplicate Duplicate existing Levee
remove Remove existing Levee
set_name Set new name of existing Levee
Additional API endpoints:
Name Description
remove_side_function Remove Side Function
remove_top_function Remove Top Function
set_angle_degrees Set Angle Degrees
set_default_height Set Default Height
set_default_width Set Default Width
set_description Set Description
set_image Set Image
set_is_fixed_size Set Is Fixed Size
set_is_relative_increase Set Is Relative Increase
set_side_function Set Side Function
set_top_function Set Top Function
set_use_existing_function Set Use Existing Function
