Resulttype (TQL Param)
| Param | Value | Description | Limits search polygon |
| Grid of Grid Overlay with specified Result Type |
Available for
- Select floorsize (TQL)
- Select height (TQL)
- Select gridavg (TQL)
- Select gridmin (TQL)
- Select gridmax (TQL)
- Select gridvolume (TQL)
- Select gridstdev (TQL)
- Select landpolygons (TQL)
- Select landsize (TQL)
- Select lotpolygons (TQL)
- Select lotsize (TQL)
- Select name (TQL)
- Select units (TQL)
- Update building attribute (TQL)
Result Types
Lists of valid Result Types:
- Result type (Average Overlay)
- Result type (Travel Distance Overlay)
- Result type (Water Overlay)
- Result type (Watershed Overlay)
- Result types (Heat Overlay)
- Result types (Heat Stress Overlay)
- Result types (Inference Overlay)
- Result types (WMS Overlay)
- This parameter should be used in combination with Grid (TQL Param), Grid with attribute (TQL Param) or Gridtype (TQL Param), and requires that you only have one Grid Overlay of the specified overlay type. Otherwise you will be unable to have control over which overlay is actually selected.
