Api session event editor indicator
Revision as of 11:40, 19 May 2026 by Frank@tygron.nl (talk | contribs)
Api session event editor indicator Endpoints.
API Endpoints for Indicator editing.
Name Description
add Add new Indicator
append_attribute Appended to existing Indicator attribute value
duplicate Duplicate existing Indicator
remove Remove existing Indicator
remove_attribute Remove attribute from Indicator
set_active Set Indicator active
set_attribute Set Indicator attribute value
set_attributes Set multiple Indicator attribute values
set_color Set new color of existing Indicator
set_name Set new name of existing Indicator
Additional API Endpoints:
Name Description
excel_min_log_time Excel Sheet Min Log Time
export_debug_excel Export Debug Excel Sheet
export_excel_call_tree Export Excel Sheet Call Tree
remove_stakeholder Remove Stakeholder
set_absolute Set Absolute
set_description Set Description
set_excel Set Excel Sheet
set_image Set Image
set_parent Set a parent Indicator for a specified Indicator. This will cause the specified Indicator to be a subselectable Indicator of the parent. It is not possible to set an Indicator which has a parent itself as a parent of another Indicator.
set_short_name Set Short Name
set_stakeholder Set Stakeholder
set_target Set a target value of an Indicator for a Sceanrio. A target index value is required.
set_update_timing Set Update Timing
swap_order Swap Order
