Neural Network (Inference Overlay)
Revision as of 14:37, 20 April 2026 by Frank@tygron.nl (talk | contribs)
Selecting a Neural Network in the Inference Overlay Wizard
A Neural Network in the Tygron Platform is a pre-trained convolution network[1] that can be used by an AI Inference Overlay to classify or detect features given one or more input Overlays. Neural Networks are stored in the Tygron Platform as data items with a reference to an ONNX-file (Open Neural Network Exchange format[2]) visible via Netron[3].
Input and output for neural networks is handled using data tensors. These tensors are multi-dimensional data arrays. They are automatically identified when selecting or adding a new Neural Network.
Whether a Neural Network classifies or detects objects given an input depends on its inference model. Such a model consists using AI-software, such as PyTorch. Neural Networks can indicate what type of network they are by defining the INFERENCE_MODE attribute in their metadata.
Supported Convolution Types
  1. Image Classification
    • Classifies a picture using labels, in combination with a predicted probability per label
  2. Detection (with masks and bounding boxes)
    • Detects up to several features in a picture
    • Predicts probabilities of features and where they are located
Parameters in Metadata
Neural Networks can also store default parameters for Inference Overlay, such that they are setup more properly once set for an Inference Overlay. The following parameters are used:
  • Neural networks that are not referenced by an AI Inference Overlay may be removed from your project when a project is saved.
API Endpoints
  1. Cheatsheet ∙ Found at: https://stanford.edu/~shervine/teaching/cs-230/cheatsheet-convolutional-neural-networks ∙ (last visited: 2024-09-21)
  2. ONNX ∙ Found at: https://onnx.ai/ ∙ (last visited: 2024-09-21)
  3. Netron ∙ Found at: https://netron.app/ ∙ (last visited: 2024-10-14)
