Api session items globals
Api session items Global Endpoints.
Edit items with event: editorglobal.
Default Query:
https://engine.tygron.com/api/session/items/globals/?f=JSON&token=API_TOKENExample Response:
"actualValue" : [ 1.0, 2.0 ],
"bookValueStakeholderID" : -1,
"calcTimeMS" : 0,
"id" : 2,
"name" : "HELLO",
"point" : null,
"previousValue" : [ 1.0, 2.0 ],
"query" : "",
"queryTiming" : "AFTER",
"startValue" : [ 1.0, 2.0 ],
"version" : 1,
"visualisationName" : ""
"actualValue" : [ 3.0, 4.0 ],
"calcTimeMS" : 0,
"id" : 3,
"name" : "HELLO2",
"point" : null,
"previousValue" : [ 3.0, 4.0 ],
"query" : "",
"startValue" : [ 3.0, 4.0 ],
"version" : 2,
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/globals/?version=100&token=API_TOKENPseudo-Mercator:
https://engine.tygron.com/api/session/items/globals/?crs=3857&token=API_TOKENDegrees:
https://engine.tygron.com/api/session/items/globals/?crs=4326&token=API_TOKENAmersfoort / RD New:
https://engine.tygron.com/api/session/items/globals/?crs=28992&token=API_TOKENLocal Coordinates:
https://engine.tygron.com/api/session/items/globals/?crs=LOCAL&token=API_TOKENbbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/globals/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKENFOO:
https://engine.tygron.com/api/session/items/globals-foo/?crs=3857&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/globals/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/globals/size/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/globals/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/globals/?f=JSON&token=API_TOKENGEOJSON:
https://engine.tygron.com/api/session/items/globals/?f=GEOJSON&token=API_TOKENGPKG:
https://engine.tygron.com/api/session/items/globals/?f=GPKG&token=API_TOKENDXF:
https://engine.tygron.com/api/session/items/globals/?f=DXF&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/globals/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/globals/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/globals/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/globals/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/globals/?f=ZIPSMILE&token=API_TOKENApi Model ActionLog
API Model description of ActionLog
| Name | Type | Description |
| action | ParticipantEventType | |
| budget | double | |
| buildingIDs | int[] | |
| id | int | |
| itemID | int | |
| mapLink | MapLink | |
| mp | MultiPolygon | |
| point | Point | |
| scoreAfter | Map<int,double> | |
| scoreBefore | Map<int,double> | |
| simTime | long | |
| stakeholderID | int | Stakeholder ID |
| subject | String | |
| version | int |
Api Model ActionMenu
API Model description of ActionMenu
| attributeActionIDs | int[] | Attribute Action ID |
| buildable | Map<int,java.util.List<java.lang.Integer>> | |
| color | TColor | |
| eventBundleIDs | int[] | Event Bundle ID |
| functionIDs | int[] | Function ID |
| id | int | |
| imageName | String | |
| imageVersion | int | |
| leveeIDs | int[] | Levee ID |
| measureIDs | int[] | Measure ID |
| name | String | |
| sortIndex | int | |
| specialOptions | Type[] | |
| upgradeIDs | int[] | Upgrade Type ID |
| version | int |
Api Model ActionType
API Enumeration description of ActionType
| Name | Description |
| CONSTRUCTION_PLAN | |
| CONSTRUCTION_PLAN_CANCEL |
Api Model Addition
API Model description of Addition
| amount | int | |
| animMultiplier | double | |
| name | String | |
| randomScale | double | |
| show | Show |
Api Model Address
API Model description of Address
| addition | String | |
| attributes | Map<String,double[]> | |
| id | int | |
| letter | String | |
| maquetteOverride | Map<String,double[]> | |
| name | String | |
| number | int | |
| point | Point | |
| sourceIDs | int[] | Source ID |
| street | String | |
| surfaceSize | double | |
| type | String | |
| version | int | |
| zipCode | String |
Api Model AddressAttribute
API Enumeration description of AddressAttribute
| ENERGY_LABEL | |
| CADASTRAL_PURPOSE | |
| RESIDENCE_TYPE | |
| INHABITANTS | |
| FLOOR_SPACE_M2 |
Api Model AeriusOverlay
API Model description of AeriusOverlay
| colorMultiplier | double | |
| colorOffset | int | |
| customLegend | boolean | |
| id | int | |
| legend | LegendEntry[] | |
| name | String | |
| parentID | int | Overlay ID |
| sortIndex | int | |
| type | OverlayType | |
| version | int | |
| visible | boolean |
Api Model Alignment
API Enumeration description of Alignment
| ROAD | |
| SPACED |
Api Model Answer
API Model description of Answer
| clientEvents | CodedEvent[] | |
| contents | String | |
| events | CodedEvent[] | |
| id | int | |
| selected | boolean |
Api Model Area
API Model description of Area
| center | Point | |
| id | int | |
| name | String | |
| polygons | MultiPolygon | |
| relations | Map<Relation,int> | |
| version | int |
Api Model AreaAttribute
API Enumeration description of AreaAttribute
| ACTIVE | |
| NATURE_RESERVE | |
| INTEREST_AREA |
Api Model AreaOverlay
API Model description of AreaOverlay
| areaIDs | int[] | Area ID |
| id | int | |
| name | String | |
| remainderColor | TColor | |
| sortIndex | int | |
| version | int | |
| visible | boolean |
Api Model AssetValue
API Enumeration description of AssetValue
| NAME | |
| DESCRIPTION | |
| ID | |
| IMAGELOCATION | |
| ROOF_COLOR | |
| BASEMENT_COLOR | |
| GROUND_COLOR | |
| EXTRA_COLOR | |
| TOP_COLOR |
Api Model AttributeItem
API Model description of AttributeItem
| id | int | |
| name | String | |
| version | int |
Api Model AttributeKey
API Enumeration description of AttributeKey
| A | |
| B | |
| C | |
| D | |
| E | |
| F | |
| G | |
| H | |
| I | |
| J |
Api Model AttributeOverlay
API Model description of AttributeOverlay
| attribute | String | |
| attributeColor | TColor | |
| colorAttribute | String | |
| id | int | |
| name | String | |
| restColor | TColor | |
| sortIndex | int | |
| version | int | |
| visible | boolean |
Api Model AttributeOverlayPredicate
API Model description of AttributeOverlayPredicate
| mapLink | MapLink |
Api Model AvgModelAttribute
API Enumeration description of AvgModelAttribute
| DISTANCE_M | |
| ATTRIBUTE_TIMEFRAMES | |
| DEFAULT_VALUE | |
| SURFACE_ONLY |
Api Model AvgOverlay
API Model description of AvgOverlay
| active | boolean | |
| calcTimeMS | long | |
| diffLegend | LegendEntry[] | |
| id | int | |
| inActiveCellSize | double | |
| inActiveTimeframes | int | |
| keys | Map<String,String> | |
| layerMapLink | MapLink | |
| maxValue | float[] | |
| minValue | float[] | |
| name | String | |
| prequels | Map<String,PrequelLink> | |
| rasterization | Rasterization | |
| resultType | String | |
| showDifference | boolean | |
| sortIndex | int | |
| version | int | |
| visible | boolean | |
| warnings | String |
Api Model BGTFunctionLink
API Model description of BGTFunctionLink
| categories | Category[] | |
| className | String | |
| functionID | int | Function ID |
| id | int | |
| layer | BGTLayer | |
| priority | int | |
| transmissionTowerFoundations | int | |
| tree | boolean | |
| typeName | String | |
| version | int |
Api Model BGTLayer
API Enumeration description of BGTLayer
| BAK | |
| BEGROEIDTERREINDEEL | |
| BORD | |
| BUURT | |
| FUNCTIONEELGEBIED | |
| GEBOUWINSTALLATIE | |
| INSTALLATIE | |
| KAST | |
| KUNSTWERKDEEL | |
| MAST | |
| ONBEGROEIDTERREINDEEL | |
| ONDERSTEUNENDWATERDEEL | |
| ONDERSTEUNENDWEGDEEL | |
| ONGECLASSIFICEERDOBJECT | |
| OPENBARERUIMTE | |
| OPENBARERUIMTELABEL | |
| OVERBRUGGINGSDEEL | |
| OVERIGBOUWWERK | |
| OVERIGESCHEIDING | |
| PAAL | |
| PUBLIC | |
| PAND | |
| PLAATSBEPALINGSPUNT | |
| PUT | |
| SCHEIDING | |
| SENSOR | |
| SPOOR | |
| STRAATMEUBILAIR | |
| TUNNELDEEL | |
| VEGETATIEOBJECT | |
| WATERDEEL | |
| WATERINRICHTINGSELEMENT | |
| WEGDEEL | |
| WEGINRICHTINGSELEMENT | |
| WIJK |
Api Model BGTTerrainLink
API Model description of BGTTerrainLink
| id | int | |
| priority | int | |
| terrainTypeID | int | Terrain Type ID |
| version | int |
Api Model BaseAttribute
API Enumeration description of BaseAttribute
| COLOR |
Api Model BaseFunction
API Model description of BaseFunction
| constructionPeriods | ConstructionPeriod[] | |
| decals | Map<FaceType,float[]> | |
| defaults | Type[] | |
| description | String | |
| dimension | int | |
| id | int | |
| modelSetID | int | Model Set ID |
| name | String | |
| placementType | PlacementType | |
| regions | Region[] | |
| textures | Map<FaceType,String> | |
| version | int |
Api Model BridgeElevation
API Enumeration description of BridgeElevation
| LOWEST | |
| TERRAIN | |
| BRIDGE |
Api Model Building
API Model description of Building
| addressIDs | int[] | Address ID |
| center | Point | |
| customGeometries | CGLink[] | |
| demolisherID | int | Stakeholder ID |
| id | int | |
| measureID | int | Measure ID |
| modelVersion | int | |
| name | String | |
| overrideCategories | Category[] | |
| overrideDecals | Map<FaceType,float[]> | |
| ownerID | int | Stakeholder ID |
| permitReceived | Map<int,Boolean> | |
| predecessorID | int | Building ID |
| sections | Section[] | |
| state | TimeState | |
| upgradeID | int | Upgrade Type ID |
| upgradeOwnerID | int | Stakeholder ID |
| version | int |
Api Model BuildingAttribute
API Enumeration description of BuildingAttribute
| CONSTRUCTION_FINISH_DATE | |
| POWER_LINE_BUILDING_ID | |
| MODEL_ANGLE | |
| POPULATION_DENSITY_M2 | |
| GEOMETRY_COLOR | |
| VACANT | |
| PRIVATE_YARD |
Api Model CGLink
API Model description of CGLink
| geometryID | int | Custom Geometry ID |
| primary | boolean |
Api Model Category
API Enumeration description of Category
| SOCIAL | |
| NORMAL | |
| LUXE | |
| ROAD | |
| PAVED_AREA | |
| EDUCATION | |
| HEALTHCARE | |
| PARK | |
| NATURE | |
| INDUSTRY | |
| OFFICES | |
| OTHER | |
| SENIOR | |
| UNDERGROUND | |
| SHOPPING | |
| AGRICULTURE | |
| LEISURE | |
| STUDENT | |
| GARDEN | |
| INTERSECTION | |
| BRIDGE |
Api Model CategoryZone
API Model description of CategoryZone
| allowedCategories | Category[] | |
| center | Point | |
| excelID | int | Excel Sheet ID |
| excelUpdated | boolean | |
| id | int | |
| name | String | |
| outline | Outline | |
| parentZoneID | int | Zone ID |
| permitterID | int | Stakeholder ID |
| version | int |
Api Model ClimateModel
API Model description of ClimateModel
| endTemp | double | |
| endYear | int | |
| oxidation | double | |
| soilTempFactor | double | |
| startTemp | double | |
| startYear | int |
Api Model CodedEvent
API Model description of CodedEvent
| id | int | |
| parameters | Object[] |
Api Model ComboModelAttribute
API Enumeration description of ComboModelAttribute
| ATTRIBUTE_DEFAULT_VALUE | |
| ATTRIBUTE_SURFACE_ONLY |
Api Model ComboOverlay
API Model description of ComboOverlay
| formula | String | |
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model ConstructionPeriod
API Enumeration description of ConstructionPeriod
| ANCIENT | |
| CLASSIC | |
| PRE_WAR | |
| POST_WAR | |
| CONTEMPORARY | |
| FUTURISTIC |
Api Model CoreStakeholder
API Model description of CoreStakeholder
| client | ClientData | |
| color | TColor | |
| id | int | |
| lastSelected | long | |
| name | String | |
| version | int | |
| webToken | String |
Api Model CostType
API Enumeration description of CostType
| CONSTRUCTION |
Api Model CustomColorArea
API Model description of CustomColorArea
| color | TColor | |
| name | String | |
| zoneID | int |
Api Model CustomGeometry
API Model description of CustomGeometry
| absoluteHeight | boolean | |
| backFaceCulling | boolean | |
| color | TColor | |
| data | float[] | |
| id | int | |
| texture | String | |
| version | int |
Api Model DataType
API Enumeration description of DataType
| FLOAT | |
| DOUBLE | |
| INT8 | |
| INT16 | |
| INT32 | |
| INT64 | |
| BOOL | |
| STRING | |
| UINT8 | |
| FLOAT16 | |
| BFLOAT16 | |
| UNKNOWN |
Api Model DefaultAttribute
API Enumeration description of DefaultAttribute
| ATTRIBUTE |
Api Model DefaultNeuralNetwork
API Model description of DefaultNeuralNetwork
| id | int | |
| legendEntries | LegendEntry[] | |
| name | String | |
| override | boolean | |
| producer | String | |
| tensors | Tensor[] | |
| uploadDate | long | |
| uploaderName | String | |
| version | int | |
| warnings | String |
Api Model DefaultOverlay
API Model description of DefaultOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model DefaultRasterizationOverlay
API Model description of DefaultRasterizationOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model DefaultResult
API Enumeration description of DefaultResult
| DEFAULT |
Api Model DefaultSource
API Model description of DefaultSource
| color | TColor | |
| date | long | |
| id | int | |
| infoUrl | String | |
| name | String | |
| version | int |
Api Model DesignAttribute
API Enumeration description of DesignAttribute
| BACKYARD_DISTANCE_M | |
| WATER_WIDTH_M | |
| KEEP_EXISTING_ROADS | |
| ROAD_WIDTH_M | |
| ROAD_DISTANCE_Y_M | |
| ROAD_SEARCH_DISTANCE_M | |
| SIDEWALK_WIDTH_M | |
| PARKING_WIDTH_M | |
| PARKING_LENGTH_M | |
| FRACTION_BUILDINGS | |
| FRACTION_ROADS | |
| FRACTION_WATER | |
| FRACTION_PUBLIC_GREEN | |
| FRACTION_GARDENS | |
| FRACTION_PARKING | |
| FRACTION_REMAINDER |
Api Model Detail
API Enumeration description of Detail
| CONSTRUCTION_COST | |
| DEMOLISH_COST | |
| BUYOUT_COST | |
| SELL_PRICE | |
| SELLABLE_FLOORSPACE_M2 | |
| NUMBER_OF_HOUSES |
Api Model DischargeMethod
API Enumeration description of DischargeMethod
| HEIGHT_MINIMA | |
| WATER_TERRAINS | |
| AREAS |
Api Model DistanceOverlay
API Model description of DistanceOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model DistanceResult
API Enumeration description of DistanceResult
| ZONE | |
| SIGHT |
Api Model EmptyMultiPolygon
API Model description of EmptyMultiPolygon
Api Model EnergyLabel
API Enumeration description of EnergyLabel
| UNKNOWN | |
| G | |
| F | |
| E | |
| D | |
| C | |
| B | |
| A0 | |
| A1 | |
| A2 | |
| A3 | |
| A4 | |
| A5 |
Api Model EventBundle
API Model description of EventBundle
| compoundEventBundleIDs | int[] | Event Bundle ID |
| id | int | |
| name | String | |
| serverEvents | CodedEvent[] | |
| version | int |
Api Model Example
API Enumeration description of Example
| CITY_NEIGHBORHOOD | |
| URBAN_NEIGHBORHOOD | |
| SUBURBAN_NEIGHBORHOOD | |
| WINDMILL_AREA |
Api Model ExcelPanel
API Model description of ExcelPanel
| answers | Answer[] | |
| contentID | int | |
| contentMapLink | MapLink | |
| height | double | |
| id | int | |
| layoutX | double | |
| layoutY | double | |
| name | String | |
| overlayID | int | Overlay ID |
| overrideDefaultAnswerID | int | |
| parentID | int | |
| point | Point | |
| text | String | |
| type | PanelType | |
| updateTiming | Timing | |
| version | int | |
| warnings | String | |
| width | double |
Api Model FaceType
API Enumeration description of FaceType
| BASEMENT | |
| GROUND | |
| EXTRA | |
| TOP | |
| ROOF |
Api Model FloodingOverlay
API Model description of FloodingOverlay
| calcInfo | String | |
| id | int | |
| mode | Mode | |
| name | String | |
| showAreas | boolean | |
| showSystem | boolean | |
| sortIndex | int | |
| version | int | |
| weatherID | int | Weather ID |
Api Model FunctionChangeGeoLink
API Model description of FunctionChangeGeoLink
| add | boolean | |
| category | Category | |
| featureAttributes | Map<String,java.util.List<java.lang.String>> | |
| id | int | |
| priority | int | |
| tree | boolean | |
| update | boolean | |
| version | int |
Api Model FunctionOverlay
API Model description of FunctionOverlay
| functionsColor | TColor | |
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| visible | boolean |
Api Model FunctionOverride
API Model description of FunctionOverride
| id | int | |
| name | String | |
| version | int |
Api Model FunctionType
API Enumeration description of FunctionType
| ROAD | |
| WATER | |
| PARKING | |
| SIDEWALK | |
| BUILDING | |
| GARDEN | |
| PUBLIC_GREEN | |
| REMAINDER |
Api Model GasType
API Enumeration description of GasType
| NOX | |
| NO2 |
Api Model GeoFormat
API Enumeration description of GeoFormat
| GEOJSON | |
| GEOPACKAGE | |
| WFS_JSON | |
| WFS_GML | |
| WMS_IMAGE | |
| WCS_TIFF | |
| OSM | |
| BGT_GML | |
| ESRI_JSON | |
| ESRI_IMAGE | |
| CYCLO_IMAGE | |
| I3S | |
| GEOTIFF | |
| DXF |
Api Model GeoTiffAttribute
API Enumeration description of GeoTiffAttribute
| BAND |
Api Model GeoTiffFeature
API Model description of GeoTiffFeature
| id | int | |
| version | int |
Api Model GeoTiffOverlay
API Model description of GeoTiffOverlay
| geoTiffIDs | int[] | GeoTIFF ID |
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model GeoTiffResult
API Enumeration description of GeoTiffResult
| NEAREST | |
| INTERPOLATED |
Api Model GeoTiffSpatial
API Model description of GeoTiffSpatial
| autoMP | boolean | |
| id | int | |
| multiPolygon | MultiPolygon | |
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model Global
API Model description of Global
| actualValue | double[] | |
| bookValueStakeholderID | int | Stakeholder ID |
| id | int | |
| name | String | |
| point | Point | |
| previousValue | double[] | |
| query | String | |
| queryTiming | Timing | |
| startValue | double[] | |
| version | int | |
| visualisationName | String |
Api Model GlobalPanel
API Model description of GlobalPanel
| globalIDs | int[] | Global ID |
| height | double | |
| id | int | |
| name | String | |
| point | Point | |
| version | int | |
| width | double |
Api Model GridFeature
API Model description of GridFeature
| id | int | |
| version | int |
Api Model GridModelAttribute
API Enumeration description of GridModelAttribute
| ITERATION_ACTIVE | |
| SKIP_NO_DATA | |
| GPU_CLUSTER_INDEX |
Api Model GridOverlay
API Model description of GridOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model GridSpatial
API Model description of GridSpatial
| id | int | |
| overlayIDs | int[] | Overlay ID |
Api Model GroundwaterOverlay
API Model description of GroundwaterOverlay
| id | int | |
| mode | Mode | |
| name | String | |
| sortIndex | int | |
| version | int | |
Api Model Group (SpecialOption)
API Enumeration description of Group
| LAND | |
| SCULPTING | |
| FINANCE | |
| DEMOLISH |
Api Model HeatDpraAttribute
API Enumeration description of HeatDpraAttribute
| DATES | |
| DAILY_AVG_RADIATION | |
| DAILY_TEMPERATURE_MAX | |
| DAILY_TEMPERATURE_MIN | |
| EXCLUDE_BUILDINGS | |
| EXCLUDE_WATER | |
| EXCLUDE_FOLIAGE_HEIGHT_M | |
| FOLIAGE_AREAS | |
| HOURLY_RADIATION | |
| HOURLY_TEMPERATURE | |
| HOURLY_HUMIDITY | |
| SUN_ALTITUDE | |
| SUN_AZIMUTH | |
| SUN_DAILY_MOTION | |
| WIND_DIRECTION | |
| WIND_SPEED | |
| DAILY_AVG_WIND_SPEED | |
| MAX_SHADOW_DISTANCE | |
| MAX_TRUNK_DISTANCE | |
| WIND_DECLINE_ANGLE |
Api Model HeatKey
API Enumeration description of HeatKey
| FOLIAGE_HEIGHT |
Api Model HeatModel
API Enumeration description of HeatModel
| UNESCO | |
| DPRA |
Api Model HeatOverlay
API Model description of HeatOverlay
| id | int | |
| model | HeatModel | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model HeatPrequel
API Enumeration description of HeatPrequel
| FOLIAGE_HEIGHT | |
| BUILDING_ELEVATION | |
| TERRAIN_ELEVATION |
Api Model HeatResult
API Enumeration description of HeatResult
| BOWEN_RATIO | |
| FOLIAGE | |
| PET | |
| PET_RELATIVE | |
| SHADE | |
| SKY_VIEW | |
| SKY_VIEW_AVG | |
| TEMPERATURE_ATMOSPHERE | |
| UHI | |
| VEGETATION | |
| VEGETATION_AVG | |
| WIND_SPEED |
Api Model HeightAttribute
API Enumeration description of HeightAttribute
| ZONING_PERMIT_REQUIRED |
Api Model HeightOperator
API Enumeration description of HeightOperator
| AVG | |
| MIN | |
| MAX | |
| VOLUME | |
| STDEV | |
| AREA |
Api Model HeightOverlay
API Model description of HeightOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model HeightResult
API Enumeration description of HeightResult
| DSM | |
| DTM | |
| FLOORS |
Api Model HeightSector
API Model description of HeightSector
| changed | Boolean | |
| envelope | Envelope | |
| id | int | |
| name | String | |
| pointAreaM2 | double | |
| pointWidth | int[] | |
| square | MultiPolygon | |
| version | int |
Api Model HeightSquare
API Model description of HeightSquare
| x | double | |
| xMax | double | |
| xMin | double | |
| y | double | |
| yMax | double | |
| yMin | double |
Api Model ImageAttribute
API Enumeration description of ImageAttribute
| ALPHA |
Api Model ImageOverlay
API Model description of ImageOverlay
| id | int | |
| imageNames | String[] | |
| name | String | |
| sortIndex | int | |
| version | int | |
| visible | boolean |
Api Model Indicator
API Model description of Indicator
| absolute | boolean | |
| currentExplanation | String | |
| exactNumberValues | Map<MapType,double> | |
| exactTextValues | Map<MapType,String> | |
| id | int | |
| isActive | boolean | |
| mapTypeValues | Map<MapType,double> | |
| maquetteExplanation | String | |
| name | String | |
| parentID | int | Indicator ID |
| shortName | String | |
| sortIndex | int | |
| targetDescriptions | String[] | |
| targets | Map<int,double[]> | |
| version | int | |
| warnings | String |
Api Model IndicatorAttribute
API Enumeration description of IndicatorAttribute
| FINANCE |
Api Model InferenceAttribute
API Enumeration description of InferenceAttribute
| MASK_THRESHOLD | |
| SCORE_THRESHOLD | |
| INFERENCE_MODE | |
| STRIDE_FRACTION | |
| BOX_OVERLAP | |
| PRIORITIZE_LABELS | |
| GPU_MEMORY_MB |
Api Model InferenceMode
API Enumeration description of InferenceMode
| CLASSIFICATION | |
| BBOX_DETECTION |
Api Model InferenceOverlay
API Model description of InferenceOverlay
| id | int | |
| name | String | |
| neuralNetworkID | int | Neural Network ID |
| sortIndex | int | |
| tensorLinks | TensorLink[] | |
| version | int | |
| warnings | String |
Api Model InferencePrequel
API Enumeration description of InferencePrequel
| A | |
| B | |
| C |
Api Model InferenceResult
API Enumeration description of InferenceResult
| LABELS | |
| SCORES | |
| BOXES | |
| MASKS | |
| DEBUG_GT_INSTANCES | |
| CENTER_POINTS |
Api Model Input
API Enumeration description of Input
| A | |
| B | |
| C | |
| D | |
| E | |
| F | |
| G | |
| H | |
| I | |
| J |
Api Model InstanceColor
API Enumeration description of InstanceColor
| GRAY | |
| WHITE | |
| VEGIE_GREEN | |
| GRAIN_YELLOW | |
| FLOWERS |
Api Model Item
API Model description of Item
| id | int | |
| version | int |
Api Model ItemMeasurement
API Model description of ItemMeasurement
| id | int | |
| itemID | int | |
| key | String | |
| maqMax | double | |
| maqMin | double | |
| max | double | |
| min | double | |
| name | String | |
| overlayMaqValues | Map<int,float[]> | |
| overlayValues | Map<int,float[]> | |
| point | Point | |
| save | boolean | |
| sum | boolean | |
| version | int |
Api Model IterationAttribute
API Enumeration description of IterationAttribute
| MODULUS | |
| TIMEFRAME_TIMES |
Api Model IterationOverlay
API Model description of IterationOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model IterationPrequel
API Enumeration description of IterationPrequel
| ITERATION |
Api Model Layer
API Enumeration description of Layer
| BRIDGE | |
| SURFACE | |
| UNDERGROUND |
Api Model LegendEntry
API Model description of LegendEntry
| color | TColor | |
| entryName | String | |
| id | int | |
| value | float |
Api Model LeveeFeature
API Model description of LeveeFeature
| id | int | |
| version | int |
Api Model LeveeSpatial
API Model description of LeveeSpatial
| angleOverride | double | |
| heightOverride | double | |
| id | int | |
| isRelativeOverride | Boolean | |
| leveeID | int | Levee ID |
| sidePolygon | MultiPolygon | |
| topPolygon | MultiPolygon |
Api Model LimitType
API Enumeration description of LimitType
| DEFAULT | |
| NEIGHBORHOODS | |
| MEASURE_NEIGHBORHOODS |
Api Model LineMeasurement
API Model description of LineMeasurement
| distances | double[] | |
| id | int | |
| lineSegment | LineSegment | |
| lineString | LineString | |
| maqMax | double | |
| maqMin | double | |
| maqValues | Map<int,java.util.ArrayList<float[]>> | |
| max | double | |
| min | double | |
| name | String | |
| save | boolean | |
| sum | boolean | |
| values | Map<int,java.util.ArrayList<float[]>> | |
| version | int |
Api Model LineString
API Model description of LineString
Api Model LoadAttribute
API Enumeration description of LoadAttribute
| CONNECTION_COST | |
| FLOW | |
| POWER | |
| CONNECTION_COUNT | |
| FLOOR_SPACE_M2 | |
| TYPE | |
| ROOT_LOAD | |
| LOAD_COUNT | |
| ADDRESS_COUNT | |
| CONNECTION_FRACTION | |
| PRESSURE_M_H2O_SUPPLY | |
| PRESSURE_M_H2O_RETURN | |
| TEMPERATURE_SUPPLY_DEGREES_CELSIUS |
Api Model LoadCostSegment
API Model description of LoadCostSegment
| baseCost | double | |
| incrCost | double | |
| minValue | int |
Api Model LoadParameterType
API Enumeration description of LoadParameterType
| FLOW | |
| POWER | |
| CONNECTION_COST | |
| CONNECTION | |
| FLOOR_SPACE_M2 |
Api Model LoadType
API Enumeration description of LoadType
| UNKNOWN | |
| COLLECTIVE | |
| COLLECTIVE_TAP | |
| COLLECTIVE_RADIATOR | |
| COLLECTIVE_RADIATOR_TAP | |
| INDIVIDUAL | |
| LARGE_SCALE_CONSUMER |
Api Model LogicPanel
API Model description of LogicPanel
| contentID | int | |
| height | double | |
| id | int | |
| name | String | |
| parentID | int | |
| point | Point | |
| text | String | |
| version | int | |
| width | double |
Api Model MapMeasure
API Model description of MapMeasure
| actualHeightChangeM3 | double | |
| buildingIDs | int[] | Building ID |
| buildingPermitProcessed | Set | |
| center | Point | |
| clientActionEvents | Map<ActionType,java.util.List<nl.tytech.data.core.item.CodedEvent>> | |
| confirmationsRequired | boolean | |
| constructionCostsFixed | double | |
| constructionCostsM3 | double | |
| custom | boolean | |
| dependencyIDs | int[] | Measure ID |
| geoTiffSpatials | GeoTiffSpatial[] | |
| gridSpatials | GridSpatial[] | |
| id | int | |
| incomeFixed | double | |
| landOwnerPermissions | Map<int,Boolean> | |
| leveeSpatials | LeveeSpatial[] | |
| name | String | |
| serverActionEvents | Map<ActionType,java.util.List<nl.tytech.data.core.item.CodedEvent>> | |
| terrainSpatials | TerrainSpatial[] | |
| upgradeSpatials | UpgradeSpatial[] | |
| version | int |
Api Model MapType
API Enumeration description of MapType
| CURRENT | |
| MAQUETTE |
Api Model Measure
API Model description of Measure
| id | int | |
| name | String | |
| version | int |
Api Model MeasureEditType
API Enumeration description of MeasureEditType
| BUILDING | |
| RAISE | |
| FLATTEN | |
| WATER | |
| UPGRADE | |
| LEVEE | |
| GEOTIFF | |
| GRID |
Api Model Method
API Enumeration description of Method
| GET | |
| POST |
Api Model MinMax
API Enumeration description of MinMax
| NEVER | |
| LARGE_CELL | |
| ALWAYS |
Api Model Mode
API Enumeration description of Mode
| SPEED | |
| AVERAGE | |
| ACCURACY |
Api Model ModelData
API Model description of ModelData
| additions | Addition[] | |
| buffer | int | |
| dimension | int | |
| frequency | int | |
| id | int | |
| instanceColor | InstanceColor | |
| isAlpha | boolean | |
| isShowCloseby | boolean | |
| modelHeight | double | |
| modelWidth | double | |
| name | String | |
| particleEmitters | ParticleEmitterCoordinatePair[] | |
| placement | Placement | |
| roots | boolean | |
| rotation | Rotation | |
| show | Show | |
| variation | int | |
| version | int |
Api Model ModelStyle
API Enumeration description of ModelStyle
| WIREFRAME | |
| PLAIN | |
| COLORED | |
| TEXTURED | |
| DISCO |
Api Model MultiLineString
API Model description of MultiLineString
Api Model MultiPolygon
API Model description of MultiPolygon
Api Model NO2Overlay
API Model description of NO2Overlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model NO2Result
API Enumeration description of NO2Result
| CONCENTRATION | |
| EMISSION_NO2 | |
| EMISSION_NOX | |
| TREEFACTOR | |
| TREES |
Api Model NeighborPredicate
API Model description of NeighborPredicate
| me | Building |
Api Model Neighborhood
API Model description of Neighborhood
| center | Point | |
| id | int | |
| municipalityID | int | Stakeholder ID |
| name | String | |
| version | int |
Api Model NeighborhoodAttribute
API Enumeration description of NeighborhoodAttribute
| URBANIZATION | |
| INHABITANTS | |
| ACTIVE |
Api Model NetFunction
API Model description of NetFunction
| diameterM | double | |
| groupName | String | |
| id | int | |
| name | String | |
| netType | NetType | |
| priceM | double | |
| version | int |
Api Model NetLine
API Model description of NetLine
| endNodeID | int | Net Node ID |
| functionID | int | Net Function ID |
| id | int | |
| name | String | |
| startNodeID | int | Net Node ID |
| version | int |
Api Model NetLineAttribute
API Enumeration description of NetLineAttribute
| FLOW | |
| DIAMETER_M | |
| ALWAYS_ACTIVE |
Api Model NetLineFunctionAttribute
API Enumeration description of NetLineFunctionAttribute
| PRICE_M | |
| VISUALIZATION_DIAMETER_M | |
| DIAMETER_M | |
| COLOR |
Api Model NetLoad
API Model description of NetLoad
| buildingID | int | Building ID |
| clusterID | int | Net Cluster ID |
| connectionState | TimeState | |
| id | int | |
| name | String | |
| nodeID | int | Net Node ID |
| point | Point | |
| version | int |
Api Model NetNode
API Model description of NetNode
| connectedLineIDs | int[] | |
| id | int | |
| loadIDs | int[] | |
| name | String | |
| point | Point | |
| version | int |
Api Model NetOverlay
API Model description of NetOverlay
| id | int | |
| name | String | |
| showActive | boolean | |
| showNetwork | boolean | |
| sortIndex | int | |
| version | int | |
| visible | boolean |
Api Model NetType
API Enumeration description of NetType
| ELECTRICITY | |
| GAS | |
| HEAT | |
| INTERNET | |
| SEWER |
Api Model NeuralNetwork
API Model description of NeuralNetwork
| id | int | |
| name | String | |
| version | int | |
| warnings | String |
Api Model NeuralNetworkAttribute
API Enumeration description of NeuralNetworkAttribute
| MIN_CELL_SIZE_M | |
| MAX_CELL_SIZE_M | |
| MAX_GT_INSTANCES | |
| VERSION |
Api Model NoPrequel
API Enumeration description of NoPrequel
Api Model NoiseOverlay
API Model description of NoiseOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model NoiseResult
API Enumeration description of NoiseResult
| NOISE_DB | |
| EMISSION |
Api Model Operator (AvgOverlay)
API Enumeration description of Operator
| AVG | |
| AVG_INTERPOLATED | |
| MAX | |
| MIN |
Api Model Operator (ComboOverlay)
| SIN | |
| COS | |
| TAN | |
| ASIN | |
| ACOS | |
| ATAN | |
| SQRT | |
| ROUND | |
| FLOOR | |
| CEIL | |
| ABS | |
| EXP | |
| LN | |
| LOG | |
| RANDOM | |
| ERF | |
| GTE | |
| GT | |
| LTE | |
| LT | |
| NEQ | |
| EQ | |
| IF | |
| AND | |
| OR | |
| SWITCH | |
| ADD | |
| MUL | |
| DIV | |
| SUB | |
| MAX | |
| MIN | |
| AVG | |
| POW | |
| PERCENTILE | |
| AVG_GTE_PERCENTILE | |
| AVG_LTE_PERCENTILE | |
| COLOR | |
| RED | |
| GREEN | |
| BLUE | |
| ALPHA |
Api Model Outline
API Enumeration description of Outline
| NONE | |
| SIMPLE | |
| DASHED |
Api Model Overlay
API Model description of Overlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| visible | boolean |
Api Model OverlayCategory
API Enumeration description of OverlayCategory
| ADMINISTRATIVE | |
| ENVIRONMENTAL | |
| WATER | |
| GRID_CALCULATION | |
| GEO_DATA | |
| TOPOGRAPHY | |
| NETWORKS |
Api Model OverlayType
API Enumeration description of OverlayType
| OWNERSHIP | |
| OWNERSHIP_GRID | |
| ZIP_CODES | |
| ZONING | |
| NEIGHBORHOODS | |
| MUNICIPALITIES | |
| SCENARIO | |
| VACANCY | |
| HEAT_STRESS | |
| SHADOW | |
| TRAFFIC_DENSITY | |
| TRAFFIC_NO2 | |
| TRAFFIC_NOISE | |
| LIVABILITY | |
| AERIUS | |
| RAINFALL | |
| FLOODING | |
| GROUNDWATER | |
| WATERSHED | |
| SUBSIDENCE | |
| WATERWIJZER | |
| AVG | |
| COMBO | |
| DISTANCE | |
| SIGHT_DISTANCE | |
| TRAVEL_DISTANCE | |
| INFERENCE | |
| ITERATION | |
| GEO_TIFF | |
| WMS | |
| WCS | |
| IMAGE | |
| AREA | |
| ATTRIBUTE | |
| FUNCTION | |
| SATELLITE | |
| HEIGHTMAP | |
| UNDERGROUND | |
| SOURCE | |
| NETWORK_OWNERSHIP | |
| NETWORK_OVERVIEW | |
| NETWORK_DISTANCE | |
| RESULT_CHILD | |
| TEST | |
| DISTURBANCE_DISTANCE | |
| SAFETY_DISTANCE | |
| DEPRECATED |
Api Model PDResult
API Model description of PDResult
| areaExisting | Map<FunctionType,double> | |
| bandMPs | Map<FunctionType,java.util.Map<java.lang.Integer, java.util.List<org.locationtech.jts.geom.MultiPolygon>>> | |
| detailMPs | Map<FunctionType,java.util.Map<java.lang.Integer, java.util.List<org.locationtech.jts.geom.MultiPolygon>>> |
Api Model Panel
API Model description of Panel
| height | double | |
| id | int | |
| name | String | |
| point | Point | |
| version | int | |
| width | double |
Api Model PanelAttribute
API Enumeration description of PanelAttribute
| VISIBLE | |
| REFRESH | |
| VISIBLE_TIMEFRAME | |
| ATTENTION | |
| SCALE | |
| POPUP_TYPE |
Api Model PanelTemplate
API Enumeration description of PanelTemplate
| TRAFFIC_NOISE | |
| DANGEROUS_OBJECTS | |
| NETWORK_INTERACTION | |
| WATER_AREAS | |
| WEIRS |
Api Model PanelType
API Enumeration description of PanelType
| GLOBAL_PANEL | |
| EXCEL_PANEL | |
| WEB_PANEL | |
| TEXT_PANEL | |
| TEMPLATE_EXCEL_PANEL | |
| TEMPLATE_TEXT_PANEL |
Api Model ParametricDesign
API Model description of ParametricDesign
| alignment | Alignment | |
| center | Point | |
| gardenID | int | Function ID |
| id | int | |
| name | String | |
| parkingID | int | Function ID |
| plotDesigns | PlotDesign[] | |
| publicGreenID | int | Function ID |
| roadID | int | Function ID |
| sidewalkID | int | Function ID |
| version | int | |
| waterID | int | Terrain Type ID |
Api Model ParticleEmitterCoordinatePair
API Model description of ParticleEmitterCoordinatePair
| id | int | |
| offsetCoordinate | double[] | |
| particleEmitterID | int | Particle Emitter ID |
Api Model Placement
API Enumeration description of Placement
| POINT | |
| EDGE |
Api Model PlacementType
API Enumeration description of PlacementType
| WATER | |
| LAND | |
| HYBRID |
Api Model Plot
API Model description of Plot
| center | Point | |
| id | int | |
| name | String | |
| version | int |
Api Model PlotDesign
API Model description of PlotDesign
| id | int | |
Api Model PlotDesignAttribute
API Enumeration description of PlotDesignAttribute
| AREA_M2 | |
| WIDTH_M | |
| SIDE_DISTANCE_M | |
| ROAD_DISTANCE_M | |
| UNITS | |
| FLOORS | |
| FLOOR_HEIGHT_M | |
| FIT_FRACTION | |
| FRACTION |
Api Model Point
API Model description of Point
Api Model PointMeasurement
API Model description of PointMeasurement
| id | int | |
| maqMax | double | |
| maqMin | double | |
| max | double | |
| min | double | |
| name | String | |
| point | Point | |
| save | boolean | |
| sum | boolean | |
| version | int |
Api Model PolygonAttributeItem
API Model description of PolygonAttributeItem
| center | Point | |
| id | int | |
| name | String | |
| version | int |
Api Model PopupData
API Model description of PopupData
| calendar | long | |
| color | TColor | |
| id | int | |
| imageType | PopupImageType | |
| linkID | int | |
| linkType | MapLink | |
| modelDataID | int | Model Data ID |
| modelType | PopupModelType | |
| name | String | |
| opensAutomatically | boolean | |
| overrideAttention | Boolean | |
| point | Point | |
| scale | double | |
| text | String | |
| title | String | |
| type | Type | |
| version | int | |
| visibleForStakeholderIDs | int[] | Stakeholder ID |
| visibleTimeframe | int |
Api Model PopupImageType
API Enumeration description of PopupImageType
| PICK_DATE | |
| REQUEST_PERMIT | |
| RECEIVE_REQUEST | |
| WAITING | |
| DECLINE | |
| APPROVE | |
| WAIT_BUILD | |
| WAIT_DEMOLISH | |
| BUILD_PROGRESS | |
| DEMOLISH_PROGRESS | |
| BUY_LAND | |
| SELL_LAND |
Api Model PopupModelType
API Enumeration description of PopupModelType
| APPROVED | |
| ARROW | |
| BUY | |
| CONNECT_ON | |
| CONNECT_OFF | |
| CONSTRUCTING | |
| ELEVATION | |
| DECLINED | |
| DEMOLISHING | |
| WAITING | |
| QUESTION_MARK | |
| TRAFFIC_NOISE | |
| WATER_CRANE | |
| WATER_ARROW | |
| WATER_WEIR | |
| LIGHT_BULB | |
| LIGHTNING | |
| BAR_CHART | |
| EXCLAMATION |
Api Model RainOverlay
API Model description of RainOverlay
| id | int | |
| mode | Mode | |
| name | String | |
| sortIndex | int | |
| version | int | |
Api Model Rasterization
API Enumeration description of Rasterization
| FIRST | |
| MIN | |
| MAX | |
| SINGLE_LAYER | |
| GRID |
Api Model RasterizationMethod
API Enumeration description of RasterizationMethod
| COMBINED | |
| OUTLINE | |
| CENTER |
Api Model RasterizationOverlay
API Model description of RasterizationOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model RasterizationPrequel
API Enumeration description of RasterizationPrequel
| INPUT |
Api Model Region
API Enumeration description of Region
| NORTH_AMERICA | |
| NORTHWESTERN_EUROPE | |
| ASIA | |
| AFRICA | |
| OTHER |
Api Model Relation
API Enumeration description of Relation
| OWNER | |
| CONSTRUCTOR | |
| DEMOLISHER | |
| PERMITTER | |
| SENDER | |
| RECEIVER | |
| NETOWNER | |
| BORDER_A | |
| BORDER_B | |
| BUILDING | |
| WEATHER | |
| PARENT | |
| RESULT_PARENT |
Api Model ResidenceType (Address)
API Enumeration description of ResidenceType
| UNKNOWN | |
| DETACHED | |
| SEMI_DETACHED | |
| PORCH | |
| TERRACED_BETWEEN | |
| TERRACED_CORNER | |
| TINY | |
| GALLERY_HOUSE | |
| FLAT | |
| APARTMENT | |
| CARAVAN | |
| HOUSE_BOAT_BERTH | |
| HOUSE_BOAT_NEW_BERTH | |
| SHARED_HOUSE | |
| ACCOMMODATION |
Api Model ResultChildOverlay
API Model description of ResultChildOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model ResultParentOverlay
API Model description of ResultParentOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model Rotation
API Enumeration description of Rotation
| FIXED | |
| QUARTER | |
| FREE |
Api Model SWRC
API Enumeration description of SWRC
| NONE | |
| VAN_GENUCHTEN |
Api Model SatelliteOverlay
API Model description of SatelliteOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model Scenario
API Model description of Scenario
| id | int | |
| limitNeighborhoodIDs | int[] | Neighborhood ID |
| limitType | LimitType | |
| name | String | |
| restartTestrun | boolean | |
| version | int |
Api Model ScenarioAttribute
API Enumeration description of ScenarioAttribute
| LIMIT_MARGIN | |
| INDICATORS |
Api Model Scope
API Enumeration description of Scope
| MAP | |
| WATER_AREAS | |
| LIMIT_AREAS | |
| OVERRIDE_RAIN_AREAS |
Api Model Section
API Model description of Section
| floors | int | |
| id | int | |
| outerLines | MultiLineString | |
| roofHeightM | double | |
| roofPolygons | GeometryCollection | |
| roofShape | float[] | |
| skeletonEnd | Point | |
| skeletonLines | MultiLineString | |
| skeletonStart | Point | |
| slantingRoofHeightM | double |
Api Model ServiceOverlay
API Model description of ServiceOverlay
| crs | String | |
| forceXY | boolean | |
| id | int | |
| layerName | String | |
| layerNames | String[] | |
| name | String | |
| sortIndex | int | |
| sourceID | int | Source ID |
| version | int | |
| warnings | String |
Api Model ServiceSource
API Model description of ServiceSource
| color | TColor | |
| date | long | |
| format | GeoFormat | |
| id | int | |
| name | String | |
| url | String | |
| version | int |
Api Model ShadowAttribute
API Enumeration description of ShadowAttribute
| DATES | |
| SUN_ALTITUDE | |
| SUN_AZIMUTH | |
| MAX_FOLIAGE_RADIUS |
Api Model ShadowOverlay
API Model description of ShadowOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model ShadowPrequel
API Enumeration description of ShadowPrequel
| FOLIAGE_HEIGHT | |
| TERRAIN_ELEVATION |
Api Model ShadowResult
API Enumeration description of ShadowResult
| SHADE | |
| FOLIAGE |
Api Model Shoreline
API Enumeration description of Shoreline
| NONE | |
| ONE_CELL | |
| TWO_CELLS |
Api Model Show
API Enumeration description of Show
| FAR | |
| MIDDLE | |
| CLOSE |
Api Model SightDistanceAttribute
API Enumeration description of SightDistanceAttribute
| SOURCE_HEIGHT_M | |
| OBSERVER_HEIGHT_M | |
Api Model SourceOverlay
API Model description of SourceOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| sources | Map<int,int> | |
| version | int | |
| visible | boolean |
Api Model SpecialEffect
API Model description of SpecialEffect
| id | int | |
| name | String | |
| point | Point | |
| version | int |
Api Model SpecialOption
API Model description of SpecialOption
| id | int | |
| name | String | |
| version | int |
Api Model Stakeholder
API Model description of Stakeholder
| color | TColor | |
| id | int | |
| name | String | |
| startBudget | double | |
| startBudgets | Map<int,double> | |
| startCinematics | Map<int,int> | |
| startPoint | Point | |
| type | Type | |
| version | int | |
| webToken | String |
Api Model Style
API Enumeration description of Style
| INTERPOLATED | |
| NEAREST | |
| ARROW | |
| COLOR | |
| FLOAT32 | |
| DIFFERENCE |
Api Model SubsidenceAttribute
API Enumeration description of SubsidenceAttribute
| YEARS | |
| YEARS_PER_TIMEFRAME | |
| START_YEAR | |
| A | |
| B | |
| C | |
| ACTIVE_DRAINAGE_FACTOR | |
| PASSIVE_DRAINAGE_FACTOR | |
| CLIMATE_START_TEMP | |
| CLIMATE_FINAL_TEMP | |
| CLIMATE_START_YEAR | |
| CLIMATE_FINAL_YEAR | |
| CLIMATE_OXIDATION | |
| CLIMATE_SOIL_TEMP_FACTOR | |
| LOW_PASSIVE_DRAINAGE | |
| HI_PASSIVE_DRAINAGE | |
| DEFAULT_PEAT_FRACTION | |
| DEFAULT_TOP_LAYER_THICKNESS | |
| DEFAULT_CLAY_THICKNESS | |
| INUNDATE_LAND_BELOW_WATER_LEVEL |
Api Model SubsidenceKey
API Enumeration description of SubsidenceKey
| WATER_LEVEL | |
| WATER_LEVEL_OUTPUT | |
| CLAY_THICKNESS | |
| INDEXATION | |
| PEAT_FRACTION | |
| TOPLAYER_THICKNESS | |
| SUBSIDENCE | |
| DRAINAGE | |
| HI_GROUND_WATER_LEVEL | |
| LOW_GROUND_WATER_LEVEL |
Api Model SubsidenceOverlay
API Model description of SubsidenceOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model SubsidencePrequel
API Enumeration description of SubsidencePrequel
| LOW_GROUND_WATER | |
| HIGH_GROUND_WATER | |
| CLAY_THICKNESS |
Api Model SubsidenceResult
API Enumeration description of SubsidenceResult
| SUBSIDENCE | |
| OXIDATION | |
| SETTLEMENT | |
| HI_GROUND_WATER |
Api Model SurfaceMode
API Enumeration description of SurfaceMode
| NONE | |
| SHALLOW | |
| AVG_WATERWAY | |
| HYBRID | |
| AVG_TERRAIN |
Api Model TColor
API Model description of TColor
Api Model TemplateExcelPanel
API Model description of TemplateExcelPanel
| autoApplied | boolean | |
| contentID | int | |
| height | double | |
| id | int | |
| name | String | |
| parentID | int | |
| point | Point | |
| relation | Relation | |
| text | String | |
| useOwner | boolean | |
| version | int | |
| width | double |
Api Model TemplateTextPanel
API Model description of TemplateTextPanel
| contentID | int | |
| height | double | |
| id | int | |
| name | String | |
| parentID | int | |
| point | Point | |
| text | String | |
| version | int | |
| width | double |
Api Model Tensor
API Model description of Tensor
| dimensions | int[] | |
| input | boolean | |
| name | String | |
| normalize | boolean | |
| type | DataType |
Api Model TensorLink
API Model description of TensorLink
| coordinate | int[] | |
| id | int | |
| normalized | boolean | |
| prequel | String | |
| result | String | |
| tensorName | String | |
| valueType | ValueType |
Api Model Terrain
API Model description of Terrain
| current | MultiPolygon | |
| heightValuesCurrent | double[] | |
| heightValuesMaquette | double[] | |
| id | int | |
| maquette | MultiPolygon | |
| name | String | |
| showSatellite | boolean | |
| typeID | int | Terrain Type ID |
| version | int |
Api Model TerrainAttribute
API Enumeration description of TerrainAttribute
| ANGLE_OF_REPOSE | |
| WATER_DEPTH_M | |
| BOWEN_RATIO | |
| BUILDABLE | |
| SUBSIDENCE | |
| COLOR | |
| HEAT_EFFECT | |
| LIVABILITY_EFFECT | |
| TERRAIN_MIX | |
| TEXTURE_TYPE | |
| WATER | |
| GROUND_INFILTRATION_MD | |
| HYDRAULIC_CONDUCTIVITY_MD | |
| HYDRAULIC_CONDUCTIVITY_WITH_THICKNESS_MD | |
| VAN_GENUCHTEN_M | |
| ROOT_DEPTH_M | |
| VEGETATION_FRACTION | |
| WATER_STORAGE_PERCENTAGE | |
| WATER_MANNING | |
| WATER_MICRORELIEF_M | |
| WATER_TRANSPIRATION_FACTOR |
Api Model TerrainFeature
API Model description of TerrainFeature
| id | int | |
| this$0 | TerrainSpatial | |
| version | int |
Api Model TerrainSpatial
API Model description of TerrainSpatial
| id | int | |
| innerHeight | double | |
| innerPolygon | MultiPolygon | |
| innerPrep | PreparedGeometry | |
| measureEditType | MeasureEditType | |
| outerPolygon | MultiPolygon | |
| outerPrep | PreparedGeometry | |
| outerRings | LineString[] | |
| relative | boolean | |
Api Model TerrainType
API Model description of TerrainType
| code | String | |
| groundLayerType | Layer | |
| id | int | |
| name | String | |
| parentID | int | Terrain Type ID |
| version | int |
Api Model TextPanel
API Model description of TextPanel
| contentID | int | |
| height | double | |
| id | int | |
| name | String | |
| parentID | int | |
| point | Point | |
| text | String | |
| version | int | |
| width | double |
Api Model TimeState
API Enumeration description of TimeState
| NOTHING | |
| WAITING_FOR_DATE | |
| REQUEST_PLOT_OWNER_APPROVAL | |
| REQUEST_ZONING_APPROVAL | |
| REQUEST_CONSTRUCTION_APPROVAL | |
| CONSTRUCTION_APPROVED | |
| CONSTRUCTION_DENIED | |
| PENDING_CONSTRUCTION | |
| CONSTRUCTING | |
| READY | |
| PENDING_UPGRADE | |
| WAITING_FOR_DEMOLISH_DATE | |
| REQUEST_DEMOLISH_ZONING_APPROVAL | |
| REQUEST_DEMOLISH_APPROVAL | |
| DEMOLISH_APPROVED | |
| DEMOLISH_DENIED | |
| PENDING_DEMOLISHING | |
| DEMOLISHING | |
| DEMOLISH_FINISHED |
Api Model Timing
API Enumeration description of Timing
| BEFORE | |
| AFTER |
Api Model TrafficAttribute
API Enumeration description of TrafficAttribute
| HOURS | |
| CARS_ACTIVE | |
| VANS_ACTIVE | |
| TRUCKS_ACTIVE | |
| BUSES_ACTIVE |
Api Model TrafficDensityOverlay
API Model description of TrafficDensityOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| visible | boolean |
Api Model TrafficNO2Attribute
API Enumeration description of TrafficNO2Attribute
| BASE_O3 | |
| BASE_NO2 | |
| EMISSION_CAR_NOX | |
| EMISSION_CAR_NO2 | |
| EMISSION_JAM_CAR_NOX | |
| EMISSION_JAM_CAR_NO2 | |
| EMISSION_VAN_NOX | |
| EMISSION_VAN_NO2 | |
| EMISSION_JAM_VAN_NOX | |
| EMISSION_JAM_VAN_NO2 | |
| EMISSION_TRUCK_NOX | |
| EMISSION_TRUCK_NO2 | |
| EMISSION_JAM_TRUCK_NOX | |
| EMISSION_JAM_TRUCK_NO2 | |
| EMISSION_BUS_NOX | |
| EMISSION_BUS_NO2 | |
| EMISSION_JAM_BUS_NOX | |
| EMISSION_JAM_BUS_NO2 | |
| ROAD1_30M_A | |
| ROAD1_30M_B | |
| ROAD1_30M_C | |
| ROAD1_60M_ALPHA | |
| ROAD1_60M_POWER | |
| MIN_TREE_HEIGHT_M |
Api Model TrafficNoiseAttribute
API Enumeration description of TrafficNoiseAttribute
| BACKGROUND_DB | |
| V0_CAR | |
| V0_VAN | |
| V0_TRUCK | |
| V0_BUS | |
| EMISSION_START_CAR | |
| EMISSION_START_VAN | |
| EMISSION_START_TRUCK | |
| EMISSION_START_BUS | |
| EMISSION_MULT_CAR | |
| EMISSION_MULT_VAN | |
| EMISSION_MULT_TRUCK | |
| EMISSION_MULT_BUS |
Api Model TrafficOverlay
API Model description of TrafficOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model TrafficType
API Enumeration description of TrafficType
| CAR | |
| VAN | |
| TRUCK | |
| BUS | |
| BICYCLE | |
| PEDESTRIAN | |
| SHIP | |
| TRAM | |
| TRAIN | |
| AIR |
Api Model TravelDistanceAttribute
API Enumeration description of TravelDistanceAttribute
| MAX_TRAVEL_DISTANCE | |
| ROAD_DISTANCE | |
| ROUTE_PEDESTRIANS | |
| ROUTE_BICYCLES | |
| ROUTE_CARS | |
| ROUTE_TRUCKS | |
| ROUTE_TRAMS | |
| ROUTE_TRAINS | |
| ROUTE_SHIPS | |
| DESTINATION_THRESHOLD | |
| BLOCKING_THRESHOLD | |
| TRAVERSABLE_THRESHOLD |
Api Model TravelDistanceKey
API Enumeration description of TravelDistanceKey
| DESTINATION_AREA | |
| BLOCKED |
Api Model TravelDistanceOverlay
API Model description of TravelDistanceOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model TravelDistancePrequel
API Enumeration description of TravelDistancePrequel
| TRAVERSABLE | |
| BLOCKING | |
| DESTINATION |
Api Model TravelDistanceResult
API Enumeration description of TravelDistanceResult
| DESTINATIONS | |
| BASE_TYPES |
Api Model Trigger
API Model description of Trigger
| id | int | |
| method | Method | |
| name | String | |
| timeoutMS | int | |
| timing | Timing | |
| type | Type | |
| url | String | |
| version | int | |
| warnings | String |
Api Model Type (PopupData)
API Enumeration description of Type
| STAKEHOLDER_STANDARD | |
| INTERACTION | |
| INTERACTION_WITH_DATE | |
| INFORMATION | |
| LABEL |
Api Model Type (SpecialOption)
| BUY_LAND | |
| SELL_LAND | |
| DEMOLISH | |
| REVERT | |
| DEMOLISH_UNDERGROUND | |
| RAISE_LAND | |
| SHOW_BUDGETPANEL | |
| SHOW_MONEY_TRANSFER_PANEL | |
| LOWER_LAND |
Api Model Type (Stakeholder)
| CIVILIAN | |
| COMPANY | |
| EDUCATION | |
| EXPERT | |
| FARMER | |
| HEALTHCARE | |
| HOUSING_CORPORATION | |
| MUNICIPALITY | |
| MEDIA | |
| PROJECT_DEVELOPER | |
| UTILITY_CORPORATION | |
| WATER_AUTHORITY | |
| OTHER_AUTHORITY | |
| OTHER |
Api Model Type (Trigger)
| TQL | |
| EVENT |
Api Model UniqueNamedItem
API Model description of UniqueNamedItem
| id | int | |
| name | String | |
| version | int |
Api Model UnitData
API Model description of UnitData
| colors | TColor[] | |
| fileName | String | |
| id | int | |
| name | String | |
| proximityWarningM | double | |
| type | TrafficType | |
| version | int |
Api Model UnitDataOverride
API Model description of UnitDataOverride
| active | Boolean | |
| id | int | |
| name | String | |
| version | int |
Api Model UpgradeFeature
API Model description of UpgradeFeature
| id | int | |
| version | int |
Api Model UpgradeSpatial
API Model description of UpgradeSpatial
| id | int | |
Api Model ValueType
API Enumeration description of ValueType
| DEFAULT | |
| R | |
| G | |
| B | |
| A |
Api Model WCSOverlay
API Model description of WCSOverlay
| crs | String | |
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model WCSResult
API Enumeration description of WCSResult
| NEAREST | |
| INTERPOLATED |
Api Model WMSOverlay
API Model description of WMSOverlay
| crs | String | |
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model WMSResult
API Enumeration description of WMSResult
| COLOR | |
| FLOAT32 | |
| RED | |
| GREEN | |
| BLUE | |
| ALPHA |
Api Model WWOverlay
API Model description of WWOverlay
| id | int | |
| name | String | |
| sortIndex | int | |
| version | int | |
| visible | boolean |
Api Model WaterKey
API Enumeration description of WaterKey
| WATER_LEVEL | |
| WATER_RELATIVE | |
| INLET_Q | |
| INLET_CAPACITY | |
| INLET_AREA | |
| LOWER_THRESHOLD | |
| UPPER_THRESHOLD | |
| UNDERGROUND | |
| INUNDATION_LEVEL | |
| AQUIFER_KD | |
| AQUIFER_DATUM | |
| SEWER_STORAGE | |
| SEWER_PUMP_SPEED | |
| WEIR_HEIGHT | |
| WEIR_WIDTH | |
| WEIR_COEFFICIENT | |
| WEIR_N | |
| WEIR_ANGLE | |
| WEIR_TARGET_LEVEL | |
| CULVERT_DIAMETER | |
| CULVERT_N | |
| CULVERT_THRESHOLD | |
| CULVERT_RECTANGULAR_HEIGHT | |
| PUMP_Q | |
| PUMP_ANGLE | |
| PUMP_AREA | |
| DRAINAGE_Q | |
| DRAINAGE_DATUM | |
| DRAINAGE_OVERFLOW_THRESHOLD | |
| DRAINAGE_ACTIVE | |
| BREACH_SPEED | |
| BREACH_HEIGHT | |
| BREACH_WIDTH | |
| BREACH_ANGLE | |
| BREACH_COEFFICIENT | |
| BREACH_INPUT_AREA | |
| BREACH_LEVEL_AREA | |
| EXTERNAL_SURFACE_LEVEL | |
| EXTERNAL_WATER_LEVEL | |
| EXTERNAL_AREA | |
| SEWER_OVERFLOW | |
| SEWER_OVERFLOW_SPEED | |
| OBJECT_FLOW_OUTPUT | |
| OBJECT_DATUM_OUTPUT_A | |
| OBJECT_DATUM_OUTPUT_B | |
| OBJECT_WIDTH_OUTPUT | |
| OBJECT_HEIGHT_OUTPUT | |
| OBJECT_WATER_AREA_OUTPUT | |
| WEIR_DAM_OUTPUT | |
| TRACER_A | |
| TRACER_B | |
| TRACER_C | |
| TRACER_D | |
| LIMIT_AREA | |
| RAIN_M |
Api Model WaterModelAttribute
API Enumeration description of WaterModelAttribute
| ALLOWED_WATER_INCREASE_M | |
| GROUND_WATERTABLE_WITH_SURFACE | |
| DESIGN_FLOOD_ELEVATION_M | |
| GROUND_BOTTOM_DISTANCE_M | |
| GROUND_BOTTOM_PRESSURE_M | |
| GROUND_WATER | |
| GROUND_WATER_DEPTH_M | |
| HYDRAULIC_CONDUCTIVITY_WITH_THICKNESS | |
| SOIL_WATER_RETENTION_CURVE | |
| UNSATURATED_FRACTION | |
| IMPACT_FLOOD_THRESHOLD_M | |
| IMPACT_RANGE_M | |
| CULVERT_DEM_THRESHOLD_M | |
| QCELL | |
| INCREASED_RESOLUTION | |
| SHORELINE | |
| OBJECT_ENTRY_CORRECTION | |
| SEWER_OVERFLOW_THRESHOLD | |
| DURATION_MIN_LEVEL_M | |
| RISE_RATE_DISTANCE_M | |
| SURFACE_WATER_EVAPORATION_FACTOR | |
| TIMEFRAMES | |
| TIMEFRAME_TIMES | |
| LIMIT_AREA | |
| LIMIT_RAIN | |
| MAX_WATER_BOTTOM_M | |
| START_DATE_MS | |
| AVG_SHORE_WIDTH_M | |
| AVG_TERRAIN_WIDTH_M | |
| AVG_TERRAIN_STORAGE_M | |
| SURFACE_WATER | |
| PREQUEL_SURFACE_LEVEL_RELATIVE | |
| MICRORELIEF_STORAGE_FRACTION | |
| MIN_MAX_ELEVATION | |
| BRIDGE_ELEVATION | |
| MAX_INFILTRATION_M | |
| MIN_DRAIN_SURFACE_DISTANCE_M | |
| INFILTRATION_FACTOR_S | |
| WEIR_DAM_MULTIPLIER | |
| WEIR_DAM_SURPLUS_HEIGHT_M | |
| BREACH_MEASUREMENT_DISTANCE_M | |
| STABILIZER_ANGLE | |
| WEIR_MOVE_INTERVAL_S | |
| WEIR_MOVE_STEP_M | |
| WEIR_MOVE_RANGE_M | |
| PARTIAL_START_SEC | |
| PARTIAL_END_SEC | |
| TRIM_MANNING | |
| TRIM_EVAPOTRANSPIRATION | |
| TRIM_ROOT_DEPTH | |
| TRIM_GROUND_INFILTRATION | |
| TRIM_GROUND_CONDUCTIVITY | |
| TRIM_SHORELINE_CONDUCTIVITY | |
| TRIM_GROUND_STORAGE_FRACTION |
Api Model WaterOverlay
API Model description of WaterOverlay
| id | int | |
| mode | Mode | |
| name | String | |
| sortIndex | int | |
| version | int | |
Api Model WaterPrequel
API Enumeration description of WaterPrequel
| TERRAIN_ELEVATION | |
| SURFACE_LEVEL | |
| SURFACE_U | |
| SURFACE_V | |
| SURFACE_INFILTRATION | |
| GROUND_WATER_DEPTH | |
| GROUND_WATER_DATUM | |
| GROUND_STORAGE_FRACTION | |
| BOTTOM_DISTANCE | |
| BOTTOM_RESISTANCE | |
| BOTTOM_PRESSURE | |
| MAX_INFILTRATION | |
| MANNING | |
| MICRORELIEF | |
| SEWER_LEVEL |
Api Model WaterResult
API Enumeration description of WaterResult
| WATER_STRESS | |
| SURFACE_LAST_DIRECTION | |
| SURFACE_AVG_DIRECTION | |
| SURFACE_DURATION | |
| SURFACE_ELEVATION | |
| SURFACE_FLOW | |
| SURFACE_LAST_FLOW | |
| SURFACE_LAST_SPEED | |
| SURFACE_LAST_VALUE | |
| SURFACE_LAST_DATUM | |
| SURFACE_MAX_SPEED | |
| SURFACE_MAX_VALUE | |
| SURFACE_EVAPORATION | |
| SURFACE_LAST_EVAPORATION | |
| BUILDING_LAST_STORAGE | |
| FLOOD_ARRIVAL_TIME | |
| FLOOD_RISE_RATE | |
| LAST_RAIN | |
| RAIN | |
| GROUND_LAST_STORAGE | |
| GROUND_LAST_VALUE | |
| GROUND_LAST_DIRECTION | |
| GROUND_FLOW | |
| GROUND_MAX_STORAGE | |
| GROUND_MAX_VALUE | |
| GROUND_WATERTABLE | |
| GROUND_BOTTOM_FLOW | |
| GROUND_LAST_UNSATURATED_STORAGE | |
| GROUND_LAST_UNSATURATED_FRACTION | |
| GROUND_TRANSPIRATION | |
| GROUND_LAST_TRANSPIRATION | |
| SEWER_LAST_VALUE | |
| SEWER_MAX_VALUE | |
| LAST_EVAPORATED | |
| LAST_EVAPOTRANSPIRATION | |
| EVAPORATED | |
| IMPACTED_BUILDINGS | |
| TRACER_A | |
| TRACER_B | |
| TRACER_C | |
| TRACER_D | |
| BASE_TYPES | |
| SURFACE_DIFFERENCE | |
| DEBUG_UV | |
| GPU_OVERVIEW | |
| DEBUG_AVG_AREAS | |
| DEBUG_UV_DIRECTION | |
| DEBUG_WATERWAYS | |
| SURFACE_LAST_U | |
| SURFACE_LAST_V |
Api Model WaterSystem
API Enumeration description of WaterSystem
| OBJECTS | |
| AREAS |
Api Model WaterType
API Enumeration description of WaterType
| NONE | |
| WATERWAY | |
| WATERBODY | |
| SEA |
Api Model WatershedKey
API Enumeration description of WatershedKey
| DISCHARGE_AREA |
Api Model WatershedModelAttribute
API Enumeration description of WatershedModelAttribute
| FILL_DISTANCE | |
| DISCHARGE_REMAINING_WATER | |
| CULVERT_FLOW_DIRECTION | |
| MIN_AREA | |
| LIMIT_ROAD |
Api Model WatershedOverlay
API Model description of WatershedOverlay
| id | int | |
| method | DischargeMethod | |
| name | String | |
| sortIndex | int | |
| version | int | |
| warnings | String |
Api Model WatershedPrequel
API Enumeration description of WatershedPrequel
| DIRECTION |
Api Model WatershedResult
API Enumeration description of WatershedResult
| WATERSHEDS | |
| DISCHARGE_AREAS | |
| DIRECTION | |
| BASE_TYPES |
Api Model WebPanel
API Model description of WebPanel
| height | double | |
| id | int | |
| name | String | |
| point | Point | |
| url | String | |
| version | int | |
| width | double |
Api Model ZipCode
API Model description of ZipCode
| color | TColor | |
| id | int | |
| name | String | |
| version | int |
Api Model Zone
API Model description of Zone
| center | Point | |
| id | int | |
| name | String | |
| version | int |
Api Model ZoneAttribute
API Enumeration description of ZoneAttribute
| MAX_BUILDING_HEIGHT | |
| MAX_ROOF_GUTTER_HEIGHT | |
| MAX_FLOORS | |
| MIN_FLOORS | |
| AMOUNT_FLOORS | |
| MAX_BUILDING_PCT | |
| MONUMENTAL |
Api Model ZoneDistanceAttribute
API Enumeration description of ZoneDistanceAttribute
| HIT_COUNT |
