Api session items globals
API Endpoint: /api/session/items/globals/
Edit items with events described at Api session event editor global.
Default Query:
https://engine.tygron.com/api/session/items/globals/?token=API_TOKENExample Response:
"actualValue" : [ 1.0, 2.0 ],
"bookValueStakeholderID" : -1,
"calcTimeMS" : 0,
"id" : 2,
"name" : "HELLO",
"point" : null,
"previousValue" : [ 1.0, 2.0 ],
"query" : "",
"queryTiming" : "AFTER",
"startValue" : [ 1.0, 2.0 ],
"version" : 1,
"visualisationName" : ""
"actualValue" : [ 3.0, 4.0 ],
"calcTimeMS" : 0,
"id" : 3,
"name" : "HELLO2",
"point" : null,
"previousValue" : [ 3.0, 4.0 ],
"query" : "",
"startValue" : [ 3.0, 4.0 ],
"version" : 2,
} ]Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/globals/?version=100&token=API_TOKENPseudo-Mercator:
https://engine.tygron.com/api/session/items/globals/?crs=3857&token=API_TOKENDegrees:
https://engine.tygron.com/api/session/items/globals/?crs=4326&token=API_TOKENAmersfoort / RD New:
https://engine.tygron.com/api/session/items/globals/?crs=28992&token=API_TOKENLocal Coordinates:
https://engine.tygron.com/api/session/items/globals/?crs=LOCAL&token=API_TOKENBbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/globals/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKENFOO:
https://engine.tygron.com/api/session/items/globals-foo/?crs=3857&token=API_TOKENGet Queries
Attributes:
https://engine.tygron.com/api/session/items/globals/attributes/?token=API_TOKENMax version:
https://engine.tygron.com/api/session/items/globals/version/?token=API_TOKENCount:
https://engine.tygron.com/api/session/items/globals/count/?token=API_TOKENSpecific Item by ID:
https://engine.tygron.com/api/session/items/globals/{id}/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/globals/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/globals/?f=JSON&token=API_TOKENGEOJSON:
https://engine.tygron.com/api/session/items/globals/?f=GEOJSON&token=API_TOKENGPKG:
https://engine.tygron.com/api/session/items/globals/?f=GPKG&token=API_TOKENDXF:
https://engine.tygron.com/api/session/items/globals/?f=DXF&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/globals/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/globals/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/globals/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/globals/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/globals/?f=ZIPSMILE&token=API_TOKENApi Model Global
API Model description of Global
| Name | Type | Description |
| actualValue | double[] | |
| bookValueStakeholderID | int | Stakeholder ID |
| calcTimeMS | long | |
| id | int | |
| name | String | |
| point | Point | Point |
| previousValue | double[] | |
| query | String | |
| queryTiming | Timing | |
| startValue | double[] | |
| version | int | |
| visualisationName | String |
Api Model Point
API Model description of Point
| type | String | Point |
| coordinates | double[] | x, y, (optional) z |
Api Model Timing
API Enumeration description of Timing
| Name | Description |
| BEFORE | |
| AFTER |
