Api session event editor indicator
Revision as of 12:07, 1 April 2026 by Frank@tygron.nl (talk | contribs)
Api session event editor indicator Events.
Indicator editing.
Name Description
ADD Add new Indicator
APPEND_ATTRIBUTE Appended to existing Indicator attribute value
DUPLICATE Duplicate existing Indicator
REMOVE Remove existing Indicator
REMOVE_ATTRIBUTE Remove attribute from Indicator
SET_ACTIVE Set Indicator active
SET_ATTRIBUTE Set Indicator attribute value
SET_ATTRIBUTES Set multiple Indicator attribute values
SET_COLOR Set new color of existing Indicator
SET_NAME Set new name of existing Indicator
Specific Events:
Name Description
EXCEL_MIN_LOG_TIME Excel Sheet Min Log Time
EXPORT_DEBUG_EXCEL Export Debug Excel Sheet
EXPORT_EXCEL_CALL_TREE Export Excel Sheet Call Tree
REMOVE_STAKEHOLDER Remove Stakeholder
SET_ABSOLUTE Set Absolute
SET_DESCRIPTION Set Description
SET_EXCEL Set Excel Sheet
SET_IMAGE Set Image
SET_PARENT Set a parent Indicator for a specified Indicator. This will cause the specified Indicator to be a subselectable Indicator of the parent. It is not possible to set an Indicator which has a parent itself as a parent of another Indicator.
SET_SHORT_NAME Set Short Name
SET_STAKEHOLDER Set Stakeholder
SET_TARGET Set a target value of an Indicator for a Sceanrio. A target index value is required.
SET_UPDATE_TIMING Set Update Timing
SWAP_ORDER Swap Order
Deprecated Events:
Name Description
DUPLICATE_INDICATOR Use DUPLICATE instead for alsmost (no Stakeholder option) identical result.
RESET_INDICATORS Replaced by editor/update/
RESET_INDICATORS_WITH_ID Replaced by editor/update_with_id/
