Api session event editor levee
Revision as of 10:11, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API api session event editor levee Events. Levee editing. {|class=wikitable !Name !Description |- |ADD |Add new Levee |- |DUPLICATE |Duplicate existing Levee |- |REMOVE |Remove existing Levee |- |SET_NAME |Set new name of existing Levee |} Specific Events: {|class=wikitable !Name !Descr...")
Levee editing.
Name Description
ADD Add new Levee
DUPLICATE Duplicate existing Levee
REMOVE Remove existing Levee
SET_NAME Set new name of existing Levee
Specific Events:
Name Description
REMOVE_SIDE_FUNCTION Remove Side Function
REMOVE_TOP_FUNCTION Remove Top Function
SET_ANGLE_DEGREES Set Angle Degrees
SET_DEFAULT_HEIGHT Set Default Height
SET_DEFAULT_WIDTH Set Default Width
SET_DESCRIPTION Set Description
SET_IMAGE Set Image
SET_IS_FIXED_SIZE Set Is Fixed Size
SET_IS_RELATIVE_INCREASE Set Is Relative Increase
SET_SIDE_FUNCTION Set Side Function
SET_TOP_FUNCTION Set Top Function
SET_USE_EXISTING_FUNCTION Set Use Existing Function
