Scenario
Revision as of 10:15, 13 November 2025 by Maxim@tygron.com (talk | contribs)
Stakeholders and Scenarios
By default, a project in the Tygron Platform always consists of at least one scenario.
When you have multiple Scenarios, for example with two different designs for you project, you can switch between them from the ribbon bar in the editor. Currently, only one scenario can be active at the same time. Actions taken in a different scenario are reverted.
Limit Map
Scenario's can be limited to a specific part of the map by selecting 'Measure Neighborhoods' in the Editor. This way only Neighborhoods that are covered by measures are active in the Scenario and the map is limited to these Neighborhoods. Using the margin attribute a margin can be added around the Neighborhoods.
The attributes and description of an active Scenario are persistent (not reset) when stopping the testrun. This allows users to store attributes for later comparison between Scenario's.
