Ground conductivity prequel (Water Overlay)
Revision as of 16:56, 24 January 2024 by Frank@tygron.nl (talk | contribs) (Created page with "{{Overlay prequels|overlay=Water|allowselflinks=true| <onlyinclude>{{Overlay prequels|type=row|overlay=Water |prequel=GROUND_CONDUCTIVITY |name=Ground conductivity |description=Used for initializing the ground conductivity, with or without thickness. |range=0 10000 |defaultvalue= |unit=m }}</onlyinclude>}} {{article end |notes=* Whether or not this prequel should be interpretated as ground conductivity with or without thickness, is configured using the model attribute [...")
| Name | Prequel | Underlying data | Unit | Range | No data | Description |
| Ground conductivity | GROUND_CONDUCTIVITY | Water Prequel | m | 0 10000 | Used for initializing the ground conductivity, with or without thickness. |
- Whether or not this prequel should be interpretated as ground conductivity with or without thickness, is configured using the model attribute Hydraulic conductivity with thickness model attribute (Water Overlay).
