Surface u prequel (Water Overlay)
Revision as of 10:56, 24 January 2024 by Frank@tygron.nl (talk | contribs) (Created page with "{{Overlay prequels|overlay=Water| <onlyinclude>{{Overlay prequels|type=row|overlay=Water |prequel=SURFACE_U |name=Surface u |description=Used for initializing the initial speed of the surface water in the x-direction. |min=-10 |max=10 |unit=m/s }}</onlyinclude>}} {{article end |notes=* The value can be set either as a relative height or datum height with attribute PREQUEL_SURFACE_LEVEL_RELATIVE. * The values in this pre...")
| Name | Prequel | Underlying data | Unit | Range | No data | Description |
| Surface u | SURFACE_U | Water Prequel | m/s | -10 to 10 | Clamped to range | Used for initializing the initial speed of the surface water in the x-direction. |
- The value can be set either as a relative height or datum height with attribute PREQUEL_SURFACE_LEVEL_RELATIVE.
- The values in this prequel grid are clamped between -10 m/s and 10 m/s.
- No data values are not allowed.
