Traffic model
Revision as of 14:34, 18 February 2022 by Rudolf@tygron.nl (talk | contribs) (Data)
Redirect page
Redirect to:
This article is a stub.
The Tygron Platform has special facility to include, visualize, modify, and use traffic data. Constructions have Function Values, can be updated in a variety of ways, and built-in Traffic Overlays use this data directly to perform spatial calculations. The entirety of all traffic data in a Project, and the rules dictating how traffic data changes through Actions taken in a Session, are collectively referred to as the Tygron Platform's traffic model.
Data
This section is a stub.
The Tygron Platform uses the following data sources to establish basic assumptions of traffic intensities:
  • NWB (Nationaal Wegen Bestand)
  • NSL Monitoring tool
  • INWEVA 2015
In addition to these default assumptions, roads for which measured traffic intensities are known will have those default values overwritten with road-specific values from the following sources:
Function Values
Grids
Dynamic traffic data
Traffic data can also be computed dynamically, either completely based on the current state of the Project, or relatively, basing new traffic values on a set of original traffic values, and computing a change in traffic based on changes in the 3D World.
Calculations
Main article: Traffic Overlay
Traffic data can be relevant for a wide range of calculations and use-cases. The Tygron Platform already contains several Traffic Overlays which compute the effects of traffic, on for example the topics of noise and NO2.
Traffic data, like any other Project data, can also be used in user-defined calculation models.
Visualization
Main article: Traffic visualization
