Water manning (Water Overlay)
Revision as of 15:09, 11 January 2022 by Rudolf@tygron.nl (talk | contribs)
The default function values for a number of constructions. The user can easily change these values.
Template:Construction attributes
Constructions have an inherent "roughness", affecting the flow of water across their surface, which is expressed by the Gauckler–Manning coefficient or, in short, Manning's value (n).
  • The manning value can be provided as a prequel.
  • The default function values are derived from online accessible databases[1] and are readily adjustable by the user.
  • If no constructions are present on a Terrain, the WATER_MANNING value of the surface terrain is used.
  1. ↑ WikiEngineer (2008-2011). Manning Roughness Coefficients. Retrieved from: http://wikiengineer.com/Water-Resources/ManningRoughnessCoefficients
Template:WaterOverlay hydrological construction attribute nav
