Radial well freatic benchmark (Water Module)
This testcase demonstrates a situation where a well is extracting ground water in a confined freatic layer. There is no aquifer present. A characteristic ground water level curve will form over time.
The lowering of the ground water table in a closed freatic layer, without additional rainfall, can be described by the following formula [1]
: stable water level at the considered stable water table edge
: water level between the considered stable water table edge and the well
: water level in the well
: hydraulic conductivity of the freatic layer in m / day
: distance to the well
: distance of the considered stable water table edge to the well
: amount of water pumped out in m³ / day
Setup
We use the following setup in our tests. The grid size used is 51 by 51, with a configurable cell size of in meters. There is one underground outlet, which pumps water away continuously with a default amount per second.
The terrain height is set to 0 meters (datum).
The outlet is placed on the cells x = 25 and y = 25 as an inlet with a negative inlet.
INLET Q is set to
UNDERGROUND is set to true (1.0) to place the outlet below the surface.
To stabilized the water levels on the edges of the test case , an additional underground inlet is used. It is located on all cells equal to or further away than the chosen R. This inlet is configured as followed:
Inlet Q set to 0, such that is unlimited.
UPPER_THRESHOLD set to -2 m.
LOWER_THRESHOLD set to -2 m.
The ground bottom distance is configured as 10 meters, which places the bottom at -10 meters (datum).
The water storage fraction is set to 0.25.
The infiltration m / day is set to 0.05.
The simulation is run for 64 days with 0 rainfall, which is configured in the weather's rain attribute as:
Test results
Important in all these tests in the chosen R, which is the distance to the well that is considered a stable water level. Additionally, the measurements are done relative to the impenetrable soil, which is situated 10 meters below the surface.
Test case 1
cell size: 5 m;
: m/day;
: 110;
: 50;
Simulation days : 64 days;
File:5m 50m3 k.png
Test case 2
cell size: 5 m;
: m/day;
: 110;
: 50;
File:5m 50m3 k.png
Test case 3
cell size: 5 m;
: m/day;
: 110;
: 50;
File:5m 50m3 k.png
Test case 4
cell size: 5 m;
: m/day;
: 110;
: 50;
File:5m 50m3 k.png
Test case 5
cell size: 5 m;
: m/day;
: 110;
: 25;
File:5m 25m3 k.png
Test case 6
cell size: 5 m;
: m/day;
: 110;
: 100;
File:5m 100m3 k.png
Test case 7
cell size: 2 m;
: m/day;
: 110;
: 1;
File:2m 1m3 k.png
Test case 8
cell size: 2 m;
: m/day;
: 110;
: 16;
File:2m 16m3 k.png
Test case 9
cell size: 2 m;
: m/day;
: 110;
: 4;
File:2m 4m3 k.png
Test case 10
cell size: 2 m;
: m/day;
: 110;
: 4;
File:2m 4m3 k.png
Test case 11
cell size: 2 m;
: m/day;
: 110;
: 4;
File:2m 4m3 k.png
  1. Verruijt, A. (1970). Theory of Groundwater Flow. Macmillan, London.
