Discharge area (Watershed Overlay)
Revision as of 11:25, 6 October 2020 by Rudolf@tygron.nl (talk | contribs)
Icon | Key | Unit | Range | Description | Default value |
DISCHARGE_AREA | boolean by presence | Identifies the Area as a unique discharge area. | n/a |
Discharge areas represent regions where rain water ends up and potentially enters the water management system to be discharged.
- A discharge area always forms the basis of a watershed. Directional water flow, or the gradient of the terrain depending on the discharge method, is backtracked to determine the watershed for a particular discharge area.
- When multiple areas overlap for a particular grid cell, only the first encountered discharge area is used.
- In the first step of the watershed algorithm, connected water cells that water cells will be assigned to this discharge area when they are not yet assigned to any discharge area.
