Export Geo data
Vector data
The objects that make up the 3D world can be exported as 2D vector data in different formats/methods. With this data, further calculations or other analysis can be done in for example GIS software. In the Current Situation tab, each of the following menus has an export Geo data option:
Raster data
File:Polygons exporteren wiki.png
(In Dutch)
Grid_Overlays can be exported as raster data or as vector data. With the exported data, calculations from for example the Water overlay can be exported to be further processed for analysis in GIS software. For exporting the grid overlays, take also note of the grid cell size. The smaller the grid size, the more accurate the exported GeoTIFF is.
The export options for raster are:
  • GeoTIFF
  • ASCII
  • WMS
The export options for vector are:
Note that the corresponding option in the Export panel is named Legend polygons. Based on the legend colors of the Grid_Overlay, a vectorisation of the raster data is created and can be exported as a GeoJSON. See also this page for more information on how to change the legend and this video tutorial: https://www.tygron.com/nl/2020/04/23/naast-geotiff-ook-polygons-exporteren-2/
How to export grid overlay calculation results:
  1. Select any grid overlay in the editor.
  2. On the right panel, select "Export Grid File".
  3. Choose the overlay, format and click on the Export button.
In the Export Grid File panel that will show up, different options for exporting are available:
  • If in a test run the option Difference (current - maquette) is selected, the difference in results between the maquette state and the current state will be exported. If you checked this option outside of the test run, or did not do any Actions yet, the exported dataset will consist no difference.
  • For grid overlays which produce multiple timeframes as results, it is possible to export a dataset at a certain timeframe, by selecting the index of the timeframe. It is also possible to export all timeframes at once by checking the All frames box.
