Groundwater level formula (Water Overlay)
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle WH_underground = \frac{W_sat}{WSP}}
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle WL_underground = WH_underground + H_surface - GBDM}
Where:
  • WLunderground = The groundwater level, relative to datum. Also known as the watertable.
  • Hsurface = The surface height in the cell, relative to datum.
Related
Features
Groundwater
Underground flow formula
Surface infiltration formula
Models
Surface model
Evaporation model
Infiltration model
Related models
Template:WaterOverlay nav
