Attribute
Revision as of 12:32, 14 February 2020 by Rudolf@tygron.nl (talk | contribs) (COLOR)
What is an Attribute?
An attribute is a characteristic or (additional) property of a component. Attributes are a common way to provide additional information or configuration for elements of data in software.
Components in the Tygron Platform with Attributes
A number of components, such as neighborhoods, areas, constructions and zones, have adjustable attributes. These attributes are used:
  • to provide meaningful information
  • as parameters in calculations
  • to provide (visual) information to distinguish themselves among peers
Attributes can be defined and redefined by a user. Some attributes are predefined by the Tygron Platform and already exist as default properties of a component. Some components can even inherit properties from other type of components, such as a Building that inherits attributes from it's referenced Function.
In general the Tygron Platform allows users to inspect, adjust and reset existing attributes of these components and define and remove new ones.
The group of components than can store attributes is called Attribute Items. The current list of Attribute Items is:
Note that although Globals seem to behave similarly to attributes, they are not part of any specific Attribute Item in a project. Instead they are individual components part of the project.
Attribute values
An attribute always consists of a name and a value. The name of an attribute is usually written in capital letters, and uses underscores in place of spaces. The value must always be a number. It can be either a positive or a negative number. The number can also be a decimal number (I.e., the value is not necessarily a whole number).
Some components have properties which are also reflected in attributes. Properties such as the color of the component are present both as a dedicated property and as an attribute. By changing the property, the attribute is changed as well. When the attribute is changed, the property is changed as well.
Each component which can have attributes has their own list of attributes. When a given area has an attribute with a specific name, another area may or may not have an attribute with the same name as well. When 2 components have an attribute with the same name, their values are also still set per component. That means that they may coincidentally have the same value, but when the value of the attribute of one component is changed, the value of the attribute of the other component is not automatically changed as well.
Attribute arrays
Main article: Attribute array
Attributes are most commonly a single value, but can also be an array of values.
Attribute values during a session
Attributes can be read during a session. Primarily, it is possible to read attributes of components using TQL. By requesting the value of an attribute of a component using TQL, the value of that attribute can be used in, for example, Excel calculations.
It is possible that, when requesting the value of an attribute of a component, that attribute does not exist for that component. In this case, the value of that attribute is deemed to be "0".
Note that this means that an attribute value of 0 can mean that the proper value of the attribute is 0, or that the attribute does not exist.
Attributes can also be changed during a session. This can be done either via Events or via TQL. Events, such as AREA_SET_ATTRIBUTE or ZONE_SET_ATTRIBUTE, can be used in the Tygron Platform to change the values of attributes. Attributes can also be changed using TQL, which means that attributes can be changed as a result of an Excel calculation.
Common attribute values
Some attributes may have a more exact spectrum of values which are valid. For example, the ACTIVE attribute is either 1 or a 0.
Note that these attributes can be given other values as well. The resulting behavior for calculations and functionality depending on these attributes is undefined.
ACTIVE
Applies to: Areas
Some components may have an "active" property. When that property indicates the component is active, the "ACTIVE" attribute's value is "1". When the component is inactive, the attribute's value is "0".
COLOR
Applies to: Areas, Neighborhoods, Zones
Main article: Color
Spatial components with attributes commonly have a "COLOR" attribute, defining the color by which they are displayed.The value corresponds to the color property of that component. When that color property is changed, the attribute is changed, and vice versa.
Examples of special attribute values
URBANIZATION
Applies to: Neighborhoods
The "URBANIZATION" attribute is an indicator for the degree of urbanization. It ranges from 1 (dense urbanization) to 5 (virtually no urbanization).
NATURE_RESERVE
Applies to: Areas
The "NATURE_RESERVE" attribute indicates whether an area is a protected area of nature. This usually means the allowance for pollution and noise is lower. Areas with an "NATURE_RESERVE" attribute value of "1" are deemed protected nature. When the attribute's value is 0, the area is not necessarily deemed protected nature.
How to add and remove attributes
Editor → The type of data to edit (Ribbon bar) → The data to edit (Left panel) → Attributes tab (Right panel)
File:Attribute tab.jpg
Switch to the Attributes tab to create or edit attributes.
File:Attribute add.jpg
The right panel allows you to add new attributes. The top half displays existing attributes, the bottom half allows you to add new attributes.
In order to add, remove, or change an attribute for any components, select the component in the left panel, and then select the attributes tab in the right panel. The attributes of that component will be displayed.
For more information how to adjust Attributes, see:
  • When removing attributes which are related to properties of the component, the value of the properties will be changed as well, as though the attribute was set to "0".
