How to import sewers
Revision as of 13:16, 11 June 2019 by Rudolf@tygron.nl (talk | contribs) (Rudolf@tygron.nl moved page How to import a sewer to How to import sewers without leaving a redirect)
Sewer areas can be imported for a water calculation when using the configuration wizard of a Water Overlay.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Water Overlay (Left panel)
How to import sewer areas for a Water Overlay:
  1. Prepare a GeoJSON file with the desired data for the sewer areas, most importantly the sewer storage.
  2. Open the configuration wizard of the Water Overlay.
  3. Continue to the step concerning sewer areas.
  4. Select the 'import' option. This will open the Geo data wizard.
  5. Follow the steps in the Geo data wizard.
  6. When the Geo Data Wizard is completed and closed, the sewer areas have been imported.
  7. The configuration wizard of the Water Overlay can now be closed as well.
In addition to sewer areas, consider importing or otherwise creating sewer overflows as well.
