Panel
Panels
In a software context, panels are windows, dialogs or similar generic interface elements which are presented to the user. Panels can either be small prompts or dialogs which facilitate an inquiry or message towards the user, or they can be larger, more complex interface components containing multiple texts and/or elements.
Usage within the Tygron Platform
In a project, panels are a term specifically used for a user-defined interface element, which can be created and configured in the editor. Panels are purposefully left generic and abstract. The contents are entirely left open for a project- or template-specific implementation. A panel can be placed inside the 3D World, where its location is indicated by a pop-up icon, which has to be clicked on to reveal the hidden panel. Panels can also be opened via client events or even left idle.
Most panels render HTML-content, which means they can display text without additional formatting. Further layout and styling can be implemented by using HTML, CSS, and JavaScript. This enables panels to also be opened in a web browser or included in the rendering of a web interface.
Types
There are 5 types of panels available in the Tygron Platform.
| Panel type | Description | Function |
| Text panel | Its contents are defined directly as text. | The text is interpreted as HTML-content and directly displayed as content of the panel. If it is HTML-formatted content, it will be displayed according the specified styling. |
| Web panel | Its contents are defined by a URL (web address). | The web page to which is referred constitutes the content of the panel. When attempting to open the panel in a web browser, the web page will be accessed directly (i.e. not via the Tygron Platform). |
| Global panel | One or more globals are linked to this panel, allowing an end-user to edit the values of those globals during a session. | The panel has a predefined structure in the session interface and a fixed location. For each linked global an input field with that global's value is displayed. This value can be altered and submitted by the end-user in the session. The value of the global will be changed accordingly. This panel does not have an HTML-representation, hence it can neither be opened in a web browser nor can it be integrated in the web interface. |
| Excel panel | Its contents are defined by an Excel file. | Each time data in the project or session are updated, the Excel file is recalculated. The results are interpreted as (HTML-formatted) text and displayed as such. Effectively, this panel is similar to a text panel, but rather than a static definition of the text content, the definition is dynamically generated through the spreadsheet. |
| Template Excel panel | This is not a panel in itself, but forms a definition by which panels can be generated automatically. The "instances" produced by a template panel behave the same as their 'regular' counterparts. | Based on how the template panel is defined, a number of "instances" of the panel will be generated. Configurations, such as the size, model, and attributes of the panel are carried over directly. The panel name, the assigned stakeholder and certain queries from the Excel file are modified based on what the template panel is applied to. |
Properties
Panels have a number of properties, which can be configured in the editor.
| Property | Description |
| Name | When a panel is opened, its name is displayed at the top, telling the end-user what the panel is about. |
| Sizing | The size of the panel can be adjusted, so that it fits the content well. It is also possible to set the location of the panel within the interface. |
| Availability | When the panel is placed in the 3D world, it can be set to either be visible or invisible. If it is set visible, it can also be told whether to draw attention or not. The panel can also be made only accessible to a specific stakeholder or a selected group of stakeholders. |
| Visualization | When the panel is placed in the 3D world, its corresponding pop-up icon is that of a green tick mark. However, there is selection of different icons available from which one can be chosen. The selected icon has both a 3D representation as well as a 2D representation for higher zoom levels and for the web interface. |
| Overlay | A panel, in itself, may not provide all the information the user wishes to show. If its content is related to specific geographic information that belongs to a certain overlay, the panel can be coupled to that overlay. Whenever the panel is opened in the future, the coupled overlay will be applied simultaneously. |
| Content | The core functionality of panels is displaying their content. Depending on the type of panel, the type of content can differ. In general, a panel without content has no purpose. |
Panels can have any number of arbitrary attributes, which allows for the attachment of additional data in an accessible and versatile fashion. Some attribute names are already reserved to fulfill a special function.
| Attribute | Unit | Description |
| ATTENTION | boolean | This is an attribute representation of the attention property and determines whether or not the panel draws attention. |
| COLOR | color | The color of the 2D version of the pop-up icon designating the panel. This can be used to differentiate between multiple pop-ups. |
| POPUP_TYPE | nominal integer | The 3D model of the pop-up and its 2D counterpart. There can be chosen from a wide selection of models. |
| SCALE | decimal value | The size of the 2D model of the pop-up in the 3D world. Note that the size is only updated when the visibility of the panel is updated. This can be done either by (re)placing it in the world or toggling its visibility. |
| VISIBLE | boolean | This is an attribute representation of the visibility property and determines whether or not the panel is visible. |
| VISIBLE_TIMEFRAME | integer | The timeframe as of when the panel (pop-up) becomes visible during simulation. This attribute requires the attribute VISIBLE to be set to 1; if not, the pop-up will not show at all. The dynamic visibility of the panel (pop-up) is only apparent when simulating a weather effect and, therefore, will not work in a normal overlay simulation run. The visualisation and division of timeframes is automatically derived from the Water Overlay present in the project. |
Use cases
Information
Interaction
Panels can also offer options to interact with the session. This can be done by means of predefined answers or through buttons defined by the HTML content, which send instructions to the project via the API. Depending on the amount of effort that went into its making, panels allow for very complex interaction in the 3D world. All types of panels allow for the implementation of "answers", though text and Excel panels also work well with HTML buttons and input elements.
Calculation model
Another utility of panels is in the form of a hidden calculation model. The Excel spreadsheet attached to an Excel panel can contain a number of equations and formulations (queries) that yield a specific outcome. For example, in the case of a dynamic traffic model, information can be retrieved first (using SELECT-queries), after which these data are processed according the following specifications in the Excel file. The end product may be the calculated traffic intensities at various locations in the 3D world. Using UPDATE-queries, these results can subsequently be implemented in the 3D world. By turning off the visibility of the Excel panel, stakeholders will not notice anything of the underlying calculation model, except for its results (e.g., changing traffic intensities).
Web interface
- Main article: Web interface
Depending on the experience you want to provide for the end user, the web interface can be enriched using your own piece of HTML, CSS and JavaScript code. This can be done within the web-interface functionality.
Adding and editing single panels
Adding/removing panels
- Select the desired panel type at the bottom of the left panel.
- Select "Add Panel".
- Select the "Single Panels" category in the left panel.
- Select the specific panel you wish to remove.
- Select "Remove".
Configuring panels
Properties
When you select a single panel, the right panel will be filled with the information pertaining to the panel. A number of properties can be configured.
| Property | Description | Example | |
| Name | The name of the panel can be adjusted in the Name field. | ||
| Panel Layout | The location of the panel in unit pixels distance from the bottom-left corner of the display. The default location is assigned "-1". The left and right input fields refer to the horizontal and vertical position, respectively. | [[File:panels-right-layout.jpg | Input fields for the panel location.]] |
| Panel Width & Height | The size of the panel in unit pixels. There is some space between the outer frame of the panel and the (inner) frame for the content within. The dimensions filled in the left and right input fields refer to the width and height of the outer frame, respectively. | ||
| Visible | The visibility of the pop-up model in the 3D world. If the panel has a location in the 3D world and its visibility is toggled on (i.e., "1"), a pop-up will show and can be interacted with. If the panel has no location in the 3D world or its visibility is toggled off, its pop-up will not show. | ||
| Request Attention | This property determines whether or not the pop-up model should draw attention in the 3D world. If the panel is set visible, has a location in the 3D world and is also set to draw attention, its pop-up will start flashing upon appearance and the end user will be shown an arrow indicating its location. | ||
| Assign to Specific Stakeholder | This property determines to which stakeholders the panel is accessible. If the checkbox is left unchecked, the panel is accessible to all stakeholders. If checked, only the stakeholder(s) indicated in the dropdown can access the panel. Other stakeholders will not be able to see the panel in the 3D world. If a stakeholder without access attempts to open the panel anyways, for instance through the web interface, they will receive an error message. | ![]() | |
| Model | The model of the panel pop-up, which consists of both a 3D model and a 2D icon. The latter is used instead of the former for high zoom levels and the web interface. A selection of models is available in the drop-down menu. | ||
| Overlay | If the panel is opened, this overlay should be activated to provide essential geographic information to the end user. If set to "NONE", no overlay is used. The overlays integrated in the current project are available in the drop-down menu. | ||
| Set Point | A panel (pop-up) can be given a location in the 3D world. This can be done by selecting the button Set Point and using the brush to select its position. To remove it again from the 3D world, select the button Remove Point. | ||
| Open Panel | Selecting the Open Panel button gives the user a preview of the panel and its content inside the session interface. This can be useful for testing purposes. The panel can also be opened in the web browser by selecting Open in Web Browser. |
Content
| Element | Instruction | Example |
| Text | Enter a text in the Panel Text field to make it the content of the panel. If the content is HTML-formatted, the content of the panel will be formatted accordingly. | ![]() |
| Web | Enter a URL in the Web Link field and the assigned web page will be opened as content of the panel. | ![]() |
| Globals | Select the globals that should be accessible through the panel. | ![]() |
| Excel | Select the Excel spreadsheet which should calculate the content for this panel. | ![]() |
Adding and editing template panels
Adding/removing template panels
- Select the "TEMPLATE_EXCEL_PANEL" type at the bottom of the left panel.
- Select the "Template Panels" category in the left panel.
- Select the template panel from which the instance was generated.
- Select "Remove".
- Select the template panel you wish to remove.
- Select "Remove".
Configuring and instantiating template panels
Template:Editor ribbon When selecting a template (Excel) panel, the right panel will provide a number of adjustable properties. Most of these are the same as for single panels, though with some important differences.
| Name | The name of the template panel. Each instance of a template panel carries a combination of this name and the name of the object. | |
| Stakeholder | The stakeholder with access to this panel. Instead of setting a specific stakeholder, one can specify the type of relation required between the stakeholder and the object in question. If the Use Owner box is checked, whichever stakeholder owns the object at the time the template panel is being applied, is set to have access to the panel.
By selecting a Relational Filter only instances of the template panel appear that meet the displayed relational criterion with the configured stakeholder. For example, if the filter is set to "Demolisher", only instances of this template panel will be generated for objects of the selected stakeholder when fulfilling the role of demolisher. |
| Template | The type of entity the template should be applied to can be selected in the Apply Template on drop-down. An additional filter can be implemented by selecting an attribute requisite from the With Attribute" drop-down. If these are set, only objects of the specified type that meet the specified attribute (i.e., contain a non-zero value) will have panel instances created. | |
| Apply template | When the template panel is configured properly, it can be used to create the actual panel instances appearing in the project. Select "Apply Template" to create the panel instances according all criteria specified above. A message will be prompted, stating the number of panel instances created. |
Note that, opposite to 'normal' panels, there is no option to directly evaluate the appearance of the template panel. This is because the template panel is merely a definition of how the actual instances should be structured, hence in itself is not an actual panel.
Editing panel instances
After applying a template panel, so that one or more panel instances are created based on the template panel, it is possible to edit them as though they were single panels. However, this practice is discouraged, because it is a common possibility that after applying the template, the template should be tweaked slightly to improve it and the instanced panels derived from it. After re-applying the template, any alterations made to specific instances of the panels are lost, as the instances are created anew. Instead, it is recommended to tag the items the panels are applied on using attributes, and including in the template panel itself some logic to handle the situations where that attribute is or isn't present.
Adding and editing answers
A panel can be given "answers". These are buttons that are added to a panel and allow the end-user to close the panel by selecting from the specified options. These "answers" can be further supplemented through the attachment of events. When the user selects an "answer" that has one or more events attached to it, these events will get fired (triggered) and will affect the session accordingly.
Adding/removing answers
- Select the panel you wish to add an answer to in the left panel.
- Select "Add Answer".
- Select the answer you wish to remove.
- Select "Remove".
Configuring answers
When you select an answer, the right panel will be filled with information pertaining to the answer. A few properties can be configured.
| Name of answer | The name of the answer. The name is displayed to the end-user when the panels is opened, and is the text of the answer the end-user may choose. The name can be changed by changing the value in the name field. | |
| Events | The events fired when this answer is selected. The events are decided into server events and client events. Server events will also trigger changes in the state of the session. Client events will only affect the visualization of the end-user who selected the answer.
For the exact steps for adding, removing, and changing events, please see Editing Events. |
Answers as part of template panels
Answers can also be added to template panels. When the template panel is applied on an item type, each event of each answer attached to the template panel is checked on whether they feature that same item type as parameters. If so, for each instance of the panel those parameters are changed to the exact item that panel instance is created for. For example, if an answer is defined with the NEIGHBORHOOD_SET_ATTRIBUTE event, and the template panel is applied on neighborhoods, each instance will have their answer with the NEIGHBORHOOD_SET_ATTRIBUTE event effect the specific neighborhood the instance is created for.
