Water Overlay
Revision as of 12:58, 13 February 2019 by Rudolf@tygron.nl (talk | contribs)
What is the Water overlay
Variants
Use cases
This section is a stub.
How to use the Water overlay
Prerequisites
Configuration
Configuration wizard
Template:Editor ribbon
Step 1: Weather
Step 2: Water system
Step 4: Interaction
Step 5: Output overlays
Step 6: Input overlays
Manual configuration
Grid cell size configuration
Main article: Grid overlay
Main section: Weather
Ground water configuration
Main section: Ground water
Subsidence configuration
Main section: Subsidence
Active in simulation setting
Result type configuration
Main section: Result type
Legend configuration
Keys configuration
Main section: Data
Attributes configuration
Main section: Attributes
Results
When the calculation completes, the results are stored as numerical values in a grid spanning the entire 3D world. The exact values and their meanings depend on the selected result type. Each timeframe and each result child overlay has it's own grid of data. There are multiple ways to interact with this data. In addition, there are a few additional outputs provided by the water overlay specifically to gain further insight, verification, and visualization of the results.
Geographical overview
Visualization
Depending on whether the option is selected, the hydrological system can be visualized when when the overlay is activated. Each water level area will be visualized by a blue floating sphere and a striped border along the terrain surface. Sewers are visualized by an orange floating sphere. If the sewer has a sewer overflow, the overflow is connected to the sewer's sphere via an orange line. Culverts, weirs, and pumps are visualized by green, orange, and red spheres respectively for their endpoints, connected by blue lines.
Hover panel
Detailed results
Timeframes
TQL
Main article: TQL
Measuring tool
Main article: Measuring tool
While viewing the overlay in the 3D client, a general impression of the values can be seen at a glance. However, depending on the configuration of the overlay's legend the exact values may be difficult to view exactly. Using the measuring tool it's possible to retrieve the values of the overlay on exact locations. Additionally, cross-sections can be defined and easily have their values inspected.
Exporting Geotiff
Additional forms of output
Weather visualization
Saving overlay result
Water balance
Debug info
Input overlay
Model connections
Terrain height
Main article: Terrain height
Template:GeoTIFFSpec
Weather
Rain and simulation time
Linear configuration
Property Unit Description
Custom configuration
Evaporation rate
Ground water
Subsidence
Data
Water level area
Sewer area
Breach
Inundation
Hydrological constructions
  • Line-based constructions
  • Point-based constructions
Culvert
Weir
Pump
Sewer overflow
Inlet
Sewered constructions
Water storage constructions
Porous constructions
Crops and foliage
Critical structures
Chemical emitters/decomposers
Water
Evaporation
Infiltration and storage
Settings
Result type
1: Water area
2: Land
3: Sewer
4: Water object
5: Breach Area
6: Active Breach
Result child overlays
Keys
The water model calculations rely on a number of calculation-wide parameters. These parameters are available as attributes of the water overlay and can be modified as such.
QUAD_CELL This attribute name is reserved for future functionality. Currently, this marks an experimental feature which is currently under development and may result in unexpected behavior when activated.
Calculations
Models
Surface model
Underground model
Rain model
Evaporation model
Surface evaporation model
Underground evaporation model
Sewer model
Storage model
Chemical flow model
Model border
Timestep formula
Δt = Δx /umax
Where:
  • Δt = computational timestep
  • Δx = grid cell size
Surface water level formula
Where:
Surface flow formula
2D Saint Venant
  • friction
  • bed slope
  • water pressure
Groundwater level formula
WHunderground = Wsat / WSP
Where:
Surface infiltration formula
Infiltration capacities:
Cwater = Wsurface
Ctop = max( Icon, Isurf )
Actual infiltration:
Δw = min( Cwater , Δt * Ctop)
Where:
S = Wunsat/Hunsat
Δw = Cinf * S
Where:
Underground flow formula
Where:
  • cell = Cell size.
Culvert formula
CHreal = max( CHattr Tright , Tright )
WHleft = max(0, WLleft-CHreal)
WHright = max(0, WLright-CHreal)
Cfull = U * A * sqrt( 2 * G * abs(WHleft - WHright) )
Cpartial = 0.9 * A * sqrt( 2 * G * abs(WHleft - WHright) )
Cculvert = Cfull
Cculvert = min( Cfull , Cpartial ) if 0.5 < (WHleft/WHright) < 2
Δw = Δt * Cculvert / cell
Where:
  • cell = Cell size.
  • Cculvert = The potential rate of water flow through the culvert.
  • Cfull = The potential rate of water flow through the culvert, if the culvert is mostly filled.
  • Cpartial = The potential rate of water flow through the culvert, if the culvert is partially filled.
  • WHleft = The height of the water column relative to the bottom of the culvert on the left side of the culvert.
  • WHright = The height of the water column relative to the bottom of the culvert on the right side of the culvert.
  • CHreal = The CULVERT_HEIGHT of the culvert, recalculated so the culvert is not below ground on either side.
  • Ufull = Loss coefficient for fully submerged culverts (0.8 to 1.0).
  • Upartial = Loss coefficient for partially submerged culverts (0.9).
  • A = Flow area, based on the highest water level.
  • CW = The CULVERT_WIDTH attribute of the culvert.
  • CHattr = The CULVERT_HEIGHT attribute of the culvert.
Weir formula
Pump formula
Δw = min( Wlower , Δt * PS )
Where:
Overflow formula
Overflow can take place when:
Hsewer + SO - Hoverflow > 0
Actual overflow:
Inlet formula
If a Tlower is defined:
If a IQ is defined:
Cspeed = Δt * IQ
If a Ctotal is defined:
Cincap = Cused - Ctotal
If a IQ is defined:
Cspeed = Δt * IQ
Coutcap = -Ctotal - Cused
Where:
  • cell = Cell size.
Surface evaporation formula
Evaporation capacities:
Δw = Δwunsat + Δwsat
Where:
Computational structure
Order of operations
  • Rain
  • Building storage
  • Sewer inflow
  • Surface evaporation
  • Underground infiltration
  • Surface infiltration
  • Exfiltration
Calculation time impacts
General Tab
Calculation Preference
Δt = Δx /umax
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
  • Water areas:
  6. Langevin, C.D., Hughes, J.D., Banta, E.R., Niswonger, R.G., Panday, Sorab, and Provost, A.M. (2017) ∙ Documentation for the MODFLOW 6 Groundwater Flow Model: U.S. Geological Survey Techniques and Methods, book 6, chap. A55 ∙ p 31 ∙ found at: https://doi.org/10.3133/tm6A55 (last visited 2019-02-04)
  7. Hydraulic Radius Equations Formulas Calculator ∙ found at: https://www.ajdesigner.com/phphydraulicradius/hydraulic_radius_equation_pipe.php ∙ (last visited 2019-02-11)
