Queries
Land polygons
| Query
Value returned
Clauses for specific query
Clauses for entire group
| LANDSIZE
Amount of surface area. (m2)
| DIKES
The amount of surface area taken up by dikes. (m2)
Construction polygons
| Query
Value returned
| LOTSIZE
Amount of surface area used by a construction. (m2)
| FLOORSIZE
The amount of floorspace, based on constructions' lotsize and their amount of floors. (m2)
| UNITS
The amount of housing units, based on construction's lotsize and their unit size.
| LOTPOLYGONS
Whether something meats the criteria (1) or not (0). When used in a panel and the panel is opened, the polygon is highlighted.
Grid values
| Query
Value returned
| GRIDAVG
The average value of a grid.
| GRIDSTDEV
The standard deviation of a grid.
| GRIDSVOLUME
The surface area multiplied by the average grid value on that surface.
| HEIGHT
The average height of the terrain. (mNAP)
- Grids (Including the value clauses)
Numeric properties
| Query
Value returned
Usable for specific query
| ATTRIBUTE
The numeric attribute value of an item.
| ID
The ID of an item (used for identification and events)
Active
| Query
Value returned
| ACTIVE
Whether the item is active/under consideration (1) or not (0).
State
| Query
Value returned
| STATE
What the current timestate is of an item.
Network
| Query
Value returned
| LENGTH
The length of pipes/lines/cables of networks.
Stakeholder finances
| Query
Value returned
| EXPENSES
The costs incurred by a stakeholder during a session.
| REVENUE
The income of a stakeholder during a session
Clauses
The following groups of clauses exist:
Main clause groups
Specific polygons
| Clause
As a polygon
As an item
Type
| AREA
It must intersect with this area.
It must be data of this area specifically.
ID indicating a specific area.
| NEIGHBORHOOD
It must intersect with this neighborhood.
It must be data of this neighborhood specifically.
ID indicating a specific neighborhood.
| ZONE
It must intersect with this zone.
It must be data of this zone specifically.
ID indicating a specific zone.
| TERRAIN
It must intersect with this terrain type.
It must be data of this type of terrain. There are no specific "instances" of terrain.
ID indicating a type of terrain.
Attribute polygons
| Clause
As a polygon
As an item
Type
| AREA_WITH_ATTRIBUTE
It must intersect with at least one area with this attribute.
N/A
Attribute name of one or more areas.
| NEIGHBORHOOD_WITH_ATTRIBUTE
It must intersect with at least one neighborhood with this attribute.
N/A
Attribute name of one or more neighborhoods.
| ZONE_WITH_ATTRIBUTE
It must intersect with at least one zone with this attribute.
N/A
Attribute name of one or more zones.
| TERRAIN_WITH_ATTRIBUTE
It must intersect with terrain with this attribute.
N/A
Attribute name of one or more terrains.
Grids
| Clause
As a polygon
As an item
Type
| MAXGRIDVALUE
It must intersect with at least this value on a grid overlay.
N/A
Decimal number.
| MINGRIDVALUE
It must intersect with at most this value on a grid overlay.
N/A
Decimal number.
| GRID
It must fall within this grid.
It must be data of this grid overlay specifically.
| GRIDTYPE
It must fall within this type of grid.
It must be data of this type of grid, not a specific "instance" of this grid.
Technical name indicating a type of grid overlay.
Note that each grid automatically covers the entire map, unless a minimum gridvalue or maximum gridvalue is defined. For queries such as GRIDAVG, this can be acceptable. However, for example, a query of SELECT_LANDSIZE_WHERE_GRID_IS_2 is functionally the same as SELECT_LANDSIZE.
Also note that when a GRIDTYPE is selected but multiple overlays of that type exist in the project, there are no guarantees on which overlay is used specifically.
Constructions
| Clause
As a polygon
As an item
Type
| BUILDING
It must intersect with this construction.
It must be data of this construction specifically.
ID indicating a specific construction.
| NET_LOAD
It must intersect with the building of this net load.
It must be data of this net load specifically.
ID indicating a specific net load.
| NET_CLUSTER
It must intersect with buildings of net loads of this net cluster.
It must be data of this net cluster specifically.
ID indicating a specific net cluster.
| FUNCTION
It must intersect with constructions of this function.
It must be data related to this function type.
ID indicating a specific function.
Dikes
| Clause
As a polygon
As an item
Type
| DIKE
It must intersect with this dike.
It must be data of this dike specifically.
ID indicating a specific dike.
Building categories
| Clause
As a polygon
As an item
Type
| CATEGORY
It must intersect with constructions of this category.
It must be related to this specific category.
Technical name indicating a category.
Timestates
| Clause
As a polygon
As an item
Type
| STATE
It must intersect with buildings or other spatial actions, which are currently in this timestate.
It must be related to this specific timestate
Technical name indicating a timestate.
| Clause
As a polygon
As an item
Type
| ATTRIBUTE_MAX
It must intersect with at least this value of an attribute.
N/A
Decimal number.
| ATTRIBUTE_MIN
It must intersect with at most this value of an attribute.
N/A
Decimal number.
| ATTRIBUTE
The attribute of which to test the value.
N/A
Attribute name of any polygonal item.
When neither a maximum or minimum value is specified, or when no attribute is specified, everything is considered
Networks
| Clause
As a polygon
As an item
Type
| NET_LINE
N/A
It must be data of this net line specifically.
ID indicating a specific net line.
| NET_LINE_DEFINITION
N/A
It must be data of net lines of this definition.
ID indicating a line definition.
| NET_TYPE
N/A
It must be data of net lines of this type of network.
ID indicating the type of network.
Stakeholders
| Clause
As a polygon
As an item
Type
| STAKEHOLDER
The land must be owned by this specific stakeholder.
It must be data of this stakeholder specifically.
ID indicating a specific stakeholder.
| STAKEHOLDERTYPE
The land must be owned by this type of stakeholder.
N/A
Technical name indicating a type of stakeholder.
Interface
| Clause
As a polygon
As an item
Type
| INDICATOR
N/A
It must be data of this indicator specifically.
ID indicating a specific indicator.
| OVERLAY
N/A
It must be data of this overlay specifically.
ID indicating a specific overlay.
| PANEL
N/A
It must be data of this panel specifically.
ID indicating a specific panel.
Minor clause groups
Variables
| Clause
As a polygon
As an item
Type
| NAME
N/A
The data requested must have this name.
The name which identifies the requested data.
Indicators
| Clause
As a polygon
As an item
Type
| INDICATORTYPE
N/A
It must be related to this type of indicator.
Technical name indicating a type of indicator.
Terms
| Clause
As a polygon
As an item
Type
| STATE
N/A
It must be related to this specific text (or "term") used by the Engine.
Technical name indicating a term.
Modifying clause groups
Map types
| Clause
As a polygon
As an item
Type
| MAP
It must be data from this moment of time in a session.
Technical name of the original/current state or the planned/maquette state.
The precise terms vary based on the simulation type, but the terms which appear in the query are CURRENT and MAQUETTE.
Layer types
| Clause
As a polygon
As an item
Type
| LAYERTYPE
It must be data from this layer of the 3D world.
N/A
Technical name of the surface or underground layers of the 3D world.
The precise terms are SURFACE and UNDERGROUND.
Multipliers
| Clause
As a polygon
As an item
Type
| ATTRIBUTE_MULT
Multiply the result by the (spatial) value of an attribute.
N/A
| FUNCTIONMULT
N/A
The name of a function value.
| CATEGORYMULT
N/A
The name of a category value.
Relations
| Clause
As a polygon
As an item
Type
| RELATION
N/A
Rather than data of the specified item, use the item which has this relation to it.
Technical name indicating a type of relation.
