UK Benchmark 3 (Water Module)
(Redirected from Benchmark 3)
This benchmark performs test case 3 of the UK benchmark [1] named Test 3 – Momentum conservation over a small obstruction as well as its result generated by the Water Module in the Tygron Platform.
The objective of the test is to assess the package’s ability to conserve momentum over an obstruction in the topography. This capability is important when simulating sewer or pluvial flooding in urbanised floodplains. The barrier to flow in the channel is designed to differentiate the performance of packages without inertia terms and 2D hydrodynamic packages with inertia terms. With inertia terms some of the flood water will pass over the obstruction.
Description
This test consists of a sloping topography with two depressions separated by an obstruction as illustrated in Figure (a & b). The dimensions of the domain are 300m longitudinally (X) x 100m transversally (Y). A varying inflow discharge, see Figure (c), is applied as an upstream boundary condition at the left-hand end, causing a flood wave to travel down the 1:200 slope. While the total inflow volume is just sufficient to fill the left-hand side depression at x=150m, some of this volume is expected to overtop the obstruction because of momentum conservation and settle in the depression on the right-hand side at x=250m. The model is run until time T=900s (15 mins) to allow the water to settle.
Below is a plan and profile of the DEM used in Test 3. The project area modeled is a perfect rectangle extending from X=0 to X=300m and from Y=0 to Y=100m as represented.
Fig. a: Top down situation.
Fig. b: Side view situation.
Fig. c: Inflow hydrograph used as upstream boundary condition.
  • Inflow boundary condition along the dashed red line in Figure (a). Table provided as part of dataset.
  • All other boundaries are closed.
  • Initial condition: Dry bed.
Parameter values
Technical setup
The provided ASCII height file named test3DEM.asc is first imported. It has a cell size of 2m, while the test is expected to run on atleast a 5m grid. We actually ran it on a 4m grid. Therefore, it will be automatically rescaled by the Rasterization process. The resulting rescaled asc file is packed in the down below.
In order to regulate the water level according to the water level graph, we used the following setup: Individual inlet objects were placed on grid cells where x = 1. The inlets were configured as:
Inlet influx graph used by the Tygron Platform
  • Inlet locations:
Inlet positions and the black rectangle indicating the border cells. The heightmap outside the border rectangle is not inside the project area.
Output as required
  • Software package used: Tygron Platform
  • Numerical scheme: FV (Kurganov, Bollermann, Horvath)*
  • Specification of hardware used to undertake the simulation:
    • Processor: Intel Xeon @2.10GHz x 8,
    • RAM 62.8 GiB,
    • GPU: 2x NVidia 1080
    • Operating system: Linux 4.13
  • Time increment used: adaptive:
  • Grid resolution: 4 m.
  • Execution time: 4 seconds for 450 timeframes
  • Inlet Q: 1189.5 m3/s
  • Remaining volume water: 1189.5 m3
  • Velocities at p1 generated by the Tygron Platform on the left and generated by others on the right.
  • Water levels for p1 generated by the Tygron Platform on the left and generated by others on the right.
  • Water levels for p2 generated by the Tygron Platform on the left and generated by others on the right.
  • Issue: Inlets provided less water using multiple 2-second timeframes (1189 m³ vs. 1310 m³ for one timeframe).
  1. ↑ Benchmarking the latest generation of 2D hydraulic modelling packages. Report: SC120002 ∙ Néelz, S., & Pender, G. (2013) ∙ Environment Agency, Horison House, Deanery Road, Bristol, BS1 9AH. ISBN: 978-1-84911-306-9 ∙ Found at: https://www.gov.uk/government/publications/benchmarking-the-latest-generation-of-2d-hydraulic-flood-modelling-packages ∙ (last visited: 2026-02-25)
