Api session event editor parametric
API Endpoint: api/session/event/editorparametric/
API Endpoints for Parametric editing.
| Name | Description |
| add | Add a Parametric Design of a particular Alignment |
| append_attribute | Appended to existing Parametric numeric Attribute value |
| duplicate | Duplicate existing Parametric |
| remove | Remove existing Parametric |
| remove_attribute | Remove numeric Attribute from Parametric |
| set_attribute | Set Parametric numeric Attribute value |
| set_attributes | Set multiple Parametric numeric Attribute values |
| set_name | Set the name of a Parametric Design |
| set_polygons | Set Polygons to existing Parametric |
Additional API Endpoints:
| add_example | Add a Parametric Design using a particular example |
| add_plot | Add a Plot Design of a particular Function to a Parametric Design |
| apply | Apply a Parametric Design for a Stakeholder, Function Types, Function IDs and one or more MultiPolygons per Function Type |
| generate | Generate a result for a Parametric Design |
| remove_plot | Remove a Plot Design of a Parametric Design |
| remove_plot_attributes | Remove Attributes from a Plot Design of a Parametric Design |
| save_as_measure | Save a Parametric Design as a new Measure for a Stakeholder, using Function Types, Function IDs and one or more MultiPolygons per Function Type |
| set_alignment | Set the alignment of a Parametric Design |
| set_function | Set a Function of a Function Type for a Parametric Design. Use Function ID -1 to remove it for a Function Type |
| set_plot_attributes | Set Attributes of a Plot Design of a Parametric Design |
| set_plot_function | Set the Function of a Plot Design of a Parametric Design |
