Api session event editor parametric add example
API Endpoint: api/session/event/editorparametric/add_example/
Description: Add a Parametric Design using a particular example
0 REQUIRED (Enumeration) Example CITY_NEIGHBORHOOD, SUBURBAN_NEIGHBORHOOD, URBAN_NEIGHBORHOOD or WINDMILL_AREA
200 Parametric Design ID
curl 'https://engine.tygron.com/api/session/event/editorparametric/add_example/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"CITY_NEIGHBORHOOD"'
JavaScript example POST
 body: '"CITY_NEIGHBORHOOD"'
fetch("https://engine.tygron.com/api/session/event/editorparametric/add_example/", options)
