Api session event editor parametric add plot
API Endpoint: api/session/event/editorparametric/add_plot/
Description: Add a Plot Design of a particular Function to a Parametric Design
| 0 | REQUIRED | (PARAMETRIC_DESIGN Integer ID or multiple integer values in array [1, 2, 3]) | Parametric Designs | |
| 1 | REQUIRED | (FUNCTION Integer ID or multiple integer values in array [1, 2, 3]) | Functions |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorparametric/add_plot/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorparametric/add_plot/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorparametric/add_plot/", options)
