Api session event editor parametric add
API Endpoint: api/session/event/editorparametric/add/
Description: Add a Parametric Design of a particular Alignment
0 REQUIRED (Enumeration) Alignment ROAD or SPACED
200 Integer (Parametric Design ID)
curl 'https://engine.tygron.com/api/session/event/editorparametric/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"ROAD"'
JavaScript example POST
 body: '"ROAD"'
fetch("https://engine.tygron.com/api/session/event/editorparametric/add/", options)
