Api session event editor geotiff
API Endpoint: api/session/event/editorgeotiff/
API Endpoints for GeoTIFF editing.
Name Description
add Add a new GeoTIFF for a GeoTIFF file provided as an array of bytes. For files larger than 2GB, use the Stream API or Web URL
remove Remove existing GeoTIFF
Additional API Endpoints:
Name Description
add_ascii Add new GeoTIFF for a provided ASCII file. For files larger than 2GB, use the Stream API or Web URL
add_ascii_url Add new GeoTIFF Item from Web ASCII URL
add_url Add a new GeoTIFF from a Web URL
export Export a GeoTIFF as a byte array. For files larger than 2GB, use the Stream API
set_geotiff Update existing GeoTIFF Item with provided file. For files larger than 2GB, use the Stream API or Web URL
set_geotiff_url Update existing GeoTIFF Item from Web URL
