Api session event editor geotiff add
API Endpoint: api/session/event/editorgeotiff/add/
Description: Add a new GeoTIFF for a GeoTIFF file provided as an array of bytes. For files larger than 2GB, use the Stream API or Web URL
0 REQUIRED (String) GeoTIFF Name
1 REQUIRED (byte or multiple values in array [a, b, c]) File bytes (< 2GB)
2 REQUIRED (String) Uploader
3 OPTIONAL (String) Override CRS
200 Integer (GeoTIFF ID)
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", 1, "Uploader" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", [ 1, 2, 3 ], "Uploader" ]'
JavaScript example POST
 body: '[ "GeoTIFF Name", 1, "Uploader" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/add/", options)
