Api session event editor geotiff set geotiff
API Endpoint: api/session/event/editorgeotiff/set_geotiff/
Description: Update existing GeoTIFF Item with provided file. For files larger than 2GB, use the Stream API or Web URL
| 0 | REQUIRED | (GEO_TIFF Integer ID) | GeoTIFF | |
| 1 | REQUIRED | (byte or multiple values in array [a, b, c]) | File bytes (< 2GB) | |
| 2 | REQUIRED | (String) | Uploader | |
| 3 | OPTIONAL | (String) | Override CRS |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/set_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Uploader" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/set_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], "Uploader" ]'JavaScript example POST
body: '[ 1, 1, "Uploader" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/set_geotiff/", options)
