Api session event editor geotiff add url
API Endpoint: api/session/event/editorgeotiff/add_url/
Description: Add a new GeoTIFF from a Web URL
0 REQUIRED (String or multiple values in array ["a", "b", "c"]) GeoTIFF Names
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Web URLs
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Uploaders
3 OPTIONAL (String or multiple values in array ["a", "b", "c"]) Override CRSs
200 Integer[] (GeoTIFF IDs)
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name 1", "Web URL 1", "Uploader 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "GeoTIFF Name 1", "GeoTIFF Name 2", "GeoTIFF Name 3" ], [ "Web URL 1", "Web URL 2", "Web URL 3" ], [ "Uploader 1", "Uploader 2", "Uploader 3" ] ]'
JavaScript example POST
 body: '[ "GeoTIFF Name 1", "Web URL 1", "Uploader 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/add_url/", options)
